FN Gloire Rebuild - was Emile Bertin Modernization
Discussion in 'Warship Builds' started by Beaver, Feb 7, 2017.
  1. Beaver
    Haven't actually looked up the specs, but I'm using these Johnson motors.
  2. Beaver
    Finished securing the motor mount and took the Emile for a stress test in the pool. No failures, and it seems to be a very solid and robust option. Definitely won't be nervous letting somebody else drive this boat.
  3. buttsakauf
    buttsakauf Well-Known Member
    Waycross, GA
    I haven't found a spec sheet. But I had a Johnson motor that looked identical that stalled at over 70A. Throw a meter on it and stall it briefly. Better to know so you don't hit some weeds and let the magic smoke out of your ESC.
  4. Beaver
  5. NickMyers
    Fuse btwn motor and esc
  6. Beaver
    What style fuses are recommended?
  7. Kevin P.
    I used to use the blade type, easy to install/replace with wire terminal things on the wire.
  8. NickMyers
    I use the atc blade fuses. Easy and readily available
    rcaircraftnut likes this.
  9. buttsakauf
    Waycross, GA
    I dislike fuses greatly. They are a quick acting single point failure. I prefer to change equipment out so that it meets my needs and runs inside the specs of the other gear. In 13yrs or so I've never let the smoke out and I've been tangled up plenty.
    SteveT44 and absolutek like this.
  10. absolutek
    Match your electronics appropriately and you won't need fuses, unless of course you like the idea of sitting on the water dead while people pound on your ship.
  11. Beaver
    Last couple nights I managed to get the wiring completed.
    Simple wiring harness. 5mm bullet connectors go to the battery, two XT60 connections for the drive and pump, and a 2mm bullet connection for the solenoid.
    Also working on internal placement of things. I think I have everything the way I like it, so here are some pics.
    Battery location in the bow with the Co2 bottle midship. This configuration actually shortens both the wiring and gas lines considerably. Need to build some sort of a holder to keep the battery in place.
    Drive ESC sits right behind the battery. Need to make a mount for that too yet.
    Pump ESC lies beside the Co2 bottle as does the firing board(not pictured). Gun solenoid sits directly behind the bottle(which needs a mount), and the pump right behind that.
    Better shot of the pump and drive motor. I need to print a cover to go over the drive chain to it doesn't devour anything. I put screening over the holes in the motor casing, but later discovered that a bb can't pass through them. Eh. I guess they'll keep balsa bits from getting in the motor. :)
    Over the 4th of July holiday I varnished the decks. It's hard to capture how good they look with a camera, but they came out really nice.
    Also got my radio configuration set up for this boat. Really nice and simple.
    That's it for now,
    Enjoy!
    SteveT44 likes this.
  12. absolutek
    Forward stick is reverse?
  13. NickMyers
    It is french
    Lou, absolutek and Beaver like this.
  14. Beaver
    That's what always felt natural for me. I guess everybody else is opposite?
  15. absolutek
    Yeah, I don't think I've ever seen somebody do that setup.
  16. Beaver
    Heh, I guess that makes me unique. :D I'll reverse it to "normal" if I ever give her to somebody to drive.
  17. SteveT44
    No balls to the walls on Caleb's boats...
  18. Beaver
    Question, the solenoid for the gun is about 12-14 inches away from the gun. Should I run all that with 1/16 hose or run it partially with 1/8 and drop down to 1/16 closer to the gun?
  19. thegeek
    move it closer, too long a run IMO
  20. Beaver
    What distance is most recommended?
