Fast Gun Texas--Operational
  1. NickMyers
    Some folk here just expel deadly gas
    Panzer, WillCover and rcaircraftnut like this.
  2. NickMyers
    Politics are generally not kosher, no good comes of those threads, hobbies are fine unless your hobby is politics :)
    Beaver, Anvil_x and rcaircraftnut like this.
  3. Anvil_x
    yeah, that's a good way to be. That's part of why I love living in an enclave north of the Wall--everybody's too busy hunting, fishing, hiking, skiing, and whatnot to waste their time with such endeavors.
    Anyways, back to the Texas.
    So I'm skinning the hull right now, and seem to be having trouble getting the contour around the foundation of the upper casemate deck. The lower casemates are pretty easy, and I have been having no troubles with the armor belt stringer at all.
    P2060019.JPG <---this guy
    So, due to this, I am thinking of using balsa for the straight outer portion, and leaving the curves open. then once I come back with the silkspan, just use that to form the contours where it requires too much flex for balsa.
    Has anyone skinned a Texas before? I'd appreciate any tips on the techniques used in that section.
    Moving on, I installed the polycarbonate armor last night. worked out incredibly well, and it'll be nice having the armor easily removable for maintenance, etc. And I gave the bottom a coat of paint. having that as the sacrificial layer has been helping me to keep my sanding on the balsa pretty light, and keeps me mindful of any sanding on the hull itself.
    Other than that, not much else happening. The Forest should be sending me my official job offer soon, and then it'll be a flurry of activity. I really hope that they're going to give me a reasonable report date, and not force me to drive down the Alcan. I don't feel like dealing with -50 and packs of wolves if breakdowns occur, especially when there can be a hundred miles between spots of humanity.
  4. Kevin P.
    Fortunately the Texas has plenty of source material out there. You definitely want balsa over all of the penetrable area. Looking at the trouble area, you might need to use a few pieces of balsa. Ideally you would have tiny ribs for the side edges, but you can probably get by without. I would use one piece for the long section, but run the grain parallel to the deck so it can curve under. Then have two small pieces for the ends.
    Looking at your pictures, generally you want to run the full pieces of balsa all the way up the sides where you can, not just to the stringer. Did you use CA to attach the sides? That method is very 2005, now a days we use contact cement, way quicker, much better seal. You’d put a couple coats on the hull, less one to two for the contact surfaces on the balsa, let dry completely, then attach. Hope this all makes sense and is useful for you
  5. Anvil_x
    "Hope", lol Kevin you're being extremely helpful. No Hope about it.
    I've got a few pre-05 tendencies since my only other foray into the hobby was with MWC in 2002-2003. I'll swing over by Lowes tonight on my way home and grab some contact cement then. With the way the stringer sits, it's forcing me to have to do it in multiple segments--it's the top step of the armor belt. the casemate stringer is another such feature. I think there are two frames on either side where I can do it in one panel.
    If I had the non-bulged Texas, it'd be a lot easier, but I like the tumbledown hull design, and have *LITERALLY NOTHING TO DO OTHER THAN WORK ON THIS BOAT*
    lol
    at least until I get my report date from USFS in Canada's cheesy Mexico.
    rcaircraftnut likes this.
  6. SteveT44
    I remember 2005. My Tin Lizzie was still shiny new from the dealer and we were only a year away from an indoor water closet! Seems just like yesterday...
  7. Beaver
    I knew you had a Model T for your first car! I've said it before... ;)
  8. Anvil_x
    lol
    so I finished sheeting the starboard side last night. got a technique dialed in for the upper casemate foundation. I'll make sure to post it up. I also figured out that forward of the upper casemates, I can do the hull with a single sheet over the stringer, as the stringer doesn't bulge out until after the casemates. The contact cement was useful for the large segments, but any spot where there was a lot of bend gave me trouble, so those parts were addressed with CA.
    looks like a noob did it, but I imagine that the port side will go a lot more smoothly.
    P2060025.JPG P2060026.JPG P2060027.JPG P2060028.JPG P2060029.JPG P2060030.JPG P2060031.JPG P2060033.JPG
    Beaver, rcaircraftnut and Kevin P. like this.
  9. SteveT44
    Did you silkspan the inside surface of the balsa before applying it?
  10. Anvil_x
    I was under the impression that I was to silkspan the outside once I had sheeted it
  11. Kevin P.
    typically we do both sides, lesson for next time
  12. SteveT44
    We really need someone to do a video of a sheet operation. Beaver, you listening! :)
  13. Anvil_x
    thanks guys, good to know. I'll span the balsa before doing the port side then
  14. Beaver
    Sure, if you do the sheeting, teaching, and talking I’ll film, edit, and get it on YouTube. :)
    Panzer, rcaircraftnut and NickMyers like this.
  15. Anvil_x
    sheeted the port side balsa, letting it dry before throwing it on tonight. Gotta run to the hobby shop later today and get more, since I used the last of it on that inner coat today.
  16. Anvil_x
    and the report date for Park Falls is 16 April. so..... I may have enough time to pound out everything except for the CO2 lines before I leave. then I'll just become PPB's problem child.
  17. rcaircraftnut
    Oklahoma
    Co2 lines takes lile 10min. I think you find 10 min to pound that out before you leave. Hahaha.
  18. Anvil_x
    supplies are the issue, not time. Seeing as how weird some things are to get in AK, I'll hold off until I get down South of The Wall. I just called the hobby shop, and *surprise* there's no silkspan left. takes three weeks to get more. so I'm going to just say "meh" and roll out some tissue on the balsa.
    If it doesn't work, I'll use it until there is a catastrophic failure.
  19. rcaircraftnut
    Oklahoma
    It will be fine. You can sheet the outside with silkspan after its on the ship. No problem. Not sure on the tissue. Or if it is legal even. Lol.
  20. rcaircraftnut
    Oklahoma
    I feel you on hard times getting supplies. I live in the way backwoods of Oklahoma on the Ar line. I have to buy ca at walmart or mail order it or drive an hour and a half one way to the lhs to overpay for 1/2 oz bottles.
