PFB's Lützow (IRCWCC)
Discussion in 'Warship Builds' started by pigeonfarmboy, Jun 27, 2016.
  1. Lou
    Lou It's just toy boats -->> C T D <<-- Admiral (Supporter)
    Cold in the morning and hot in the afternoon, I think you need an idler
  2. pigeonfarmboy
    Champaign, IL
    Productive Friday night. Ended up incorporating the servo mount and rudder post together in one piece. Machined a pocket in the top to both lighten the plastic block and have the option if needed to add ballast to the stern. Measuring the slope of the internal stern hull and transferring that to the plastic block worked out better than expected. The servo mount is probably strong enough to just use the single side but in the spirit of over-building everything I'll put in a mounting block for the opposite side. The assembly fits under the stern deck perfectly.
      File size:
      148.6 KB
      159
      File size:
      161.6 KB
      159
    Xanthar, SteveT44, Lou and 2 others like this.
  3. Beaver
    Very nice mount!
    pigeonfarmboy likes this.
  4. pigeonfarmboy
    Champaign, IL
    Got prop shafts aligned and ready for mounting tonight. They are dead-on level to the hull with enough clearance for the drive cups to fit.
  5. pigeonfarmboy
    Champaign, IL
    Stuffing tubes are in and the struts are now curing. Planning to get the gearbox and rudder assembly installed tonight. Possibly start on water channeling if time plays in my favor.
  6. pigeonfarmboy
    Champaign, IL
    Fought with prop shaft fitting most of the night but it's all fitted and ready for the gearbox mount next. Laid down some basic shapes for skegs too, will sand into a more streamlined and matching shape tomorrow. Glad I have a 4-day weekend coming up before nats!
  7. WillCover
    WillCover -->> C T D <<--
    Harrison, Michigan
    51QsD9792uL._SX355_.jpg TIC-TOC, TIC-TOC
  8. SteveT44
    Impressive globs of plastic!
  9. kgaigalas
    kgaigalas Well-Known Member
    Grand Rapids, Michigan
    Will you solder your props to your shafts?
  10. pigeonfarmboy
    Champaign, IL
    That's the Smooth-On Freeform Air epoxy. (Somebody learned last night that mixing up a large batch makes it cook off REALLY fast)
  11. pigeonfarmboy
    Champaign, IL
    It's tough to get at the drive cup set screws as they ended up under the drop down decking so I'll need to be able to assemble the shafts drive cups first/props last. Current plan is to grind flats on the shafts and use red loctite on the set screws. Just have to use a soldering iron or pencil torch to melt the glue when I need to service something. May even put the threadlock on the shaft when installing the prop almost like using a bearing set. Will scratch my head on it some more and report back.
  12. pigeonfarmboy
    Champaign, IL
    Got started on the water channeling. Servo/Rudder mount is all installed and functional. Props and drive cups are in. Almost finished with the gearbox mount as well.
    Servo/Rudder belt mount in action: https://flic.kr/p/W74vdr
      File size:
      114.8 KB
      120
      File size:
      141.4 KB
      125
    WillCover and Beaver like this.
  13. pigeonfarmboy
    Champaign, IL
    More water channeling and the solenoid mounts are in. Lost a full day yesterday to food poisoning. Guess I needed more of a challenge....
      File size:
      143.8 KB
      116
      File size:
      141.6 KB
      115
  14. Beaver
    You're doing a very good job. Would never know this was your first boat! :) Keep at it, I love seeing your work.:)
  15. pigeonfarmboy
    Champaign, IL
    Much appreciated sir! I'm aware I'm makin it hard on myself not just slapping kit parts in it but my inner machinist can't be tamed sometimes.
  16. pigeonfarmboy
    Champaign, IL
    Cannons are mounted and the magazines are fixed to the deck. Just need to wrap the mags with pvc tubing for armor.
  17. pigeonfarmboy
    Champaign, IL
    Got a fair amount done. Unfortunately I think I'll be skinning and painting on Sunday @ Nats.
    In a moment of panic I decided to test the hulls "sinkability" worried maybe the smooth-on putty may be too buoyant. Luckily it's not enough to effect it.
    Electronics are waterproofed
    Battery and Tank mounts are installed
    Air lines are plumbed (I am now a certified PTC expert haha)
    Pump Mount is in, need to run the outlet through the step down deck
    Had this chain around from my 1/14 Semi Trucks that worked well for anchor chain
    Tonight's focus will be finishing superstructure and figuring out a recovery float. Installing electronics and internal armor. Also need to make a transport stand.
      File size:
      242.1 KB
      108
      File size:
      107.9 KB
      107
      File size:
      193.1 KB
      108
      File size:
      297.3 KB
      107
      File size:
      179.3 KB
      108
      File size:
      95.9 KB
      108
      File size:
      106.7 KB
      107
  18. Beaver
    Looking good! How easy is it to get the Co2 bottle out of that mount?
  19. Lou
    Can you make the deck removable (for when you have extreme issues)?
  20. pigeonfarmboy
    Champaign, IL
    Using reusable zip ties or velcro straps will make it easy. Didn't have any on hand.
