12 or 16 gram co2
Discussion in 'Weapons & Pneumatics' started by Evil Joker, Jul 21, 2008.
  1. Evil Joker
    Evil Joker Member
    witch one would you go with its for a (my)Scipione Africano. Capitani Romani class. one gun with a Solenoid and a rtb Regulator.the weight is not un issue http://www.rcnavalcombat.com/FileManager/Storage/633522672289375000.png .....http://www.rcnavalcombat.com/FileManager/Storage/633522671778125000.png how many shots would you get out of each and why and why not would you use them thank you steve
  2. webwookie
    webwookie Active Member
    I can't quite tell from the photos you listed but if I'm not mistaken, most 12g CO2 cartridges are unthreaded and require a holder of one form or another to facilitate their use while 16g cartridges are threaded and can thus be used with the appropriate adapter (no holder required).
  3. Evil Joker
    Evil Joker Member
    i have to use threaded do to the rtb (Rock-the-Boat)
    Regulator and i can get threaded 12 gram. 16 are easier to get but a litte more money i dont even know what you all use this is what i came up with if um wrong let me know
  4. HMCS
    HMCS Active Member
    HMS Abdiel uses 12g, they're unthreaded, I use the adapter BC sells for them. I have a BC 50 round straight mag cannon with SS barrel and I get 54-57 shots a capsule. Bob Pottle if I'm not mistaken used 16g in his 1 gun ships HMS Gorgon and HMCS Prince Robert.He's still away but can probably provide some details when he returns.
    Main reason I went with 12g was because I can go to the nearest Canadian Tire Hardware and buy a box of 40.
  5. Evil Joker
    Evil Joker Member
    thats were i mest up i have Input: 3/8"-24 threads regulator can bc adapter fix that for me
