16-gram cartridges
Discussion in 'General' started by Renodemona, Aug 20, 2007.
  1. Renodemona
    Hey, not sure if this should be under guns so if it is sorry :( Will a 16-gram cartridge be enough C02 for two cannons? I'm really wanting to put an Agono on the water for nats next year set up with dual sterns. Wieght might be an issue, so using a 16gram setup would be cool. But is it enough?
  2. specialist
    specialist Active Member
    Probibly not.
    A 12 gram is not really enough for 1 cannon. Depending on pressure, you might expect ~45 shots from a 12 gram.
    A 16 gram might be enough for 1 cannon.
