For flyers I hear they are as good as the Spektrum radios. For our hobby I do not think it makes that much of a difference.
Joker, that is correct. Microwaves don't penetrate water well at all. For the Spektrums, you can buy a bigger battery or replace the voltage regulator ($18 for the regulator, some soldering required). Or both! I did the regulator, it's not really hard, but not for the faint of heart. If putting buttons in a transmitter is 4 out of 10, the regulator is a 6, and you NEED a temperature-controlled soldering iron. If you are a really precise solder-soldier, it's more like a 5 out of 10. Getting the old VR off the board is tricky, a in more recent radios, they've taken to using adhesive to hold the body of the VR to the board. Older Spektrum VRs were just held in place by the solder leads. Sorry for jumping into a FASST discussion
Of course, firing guns underwater can be hard on guns. Especioally Bug Gun style turrets. That is why there are such things as attached floats, after all. Cheers,
I'm going to check out what Kranzel's Hobbies has in stock. Do a "hands on" test. Thanks for all the info
The Futaba 2.4 gig radio I have has worked with out fail for 1 year now. No gliches, twiches, or twitering. They are said to put out 10X the broadcast power of a Spectrum. Battery like is good, and are rated to draw less current than a stardard Futaba radio. I guess they did not use the same cheep voltage converter that Spectrum did. I do not know about reception under water.
Thanks for the info there specialist. Can you get back to me on the "reception under water"? Thanks again,
Anything in your club rules that prevents a recovery float? It is a lot easier to recover a ship by grabbing the float and fishing it in that to send swimmers in to find it. Safer, too. Cheers,
Nope, some guys have float systems that work pretty well. I personally like to sink where its shallow!
Me too but I still have floats in case I dont make it [] besides once a listing ship heads to shallow the other ships are on it like seagulls to the catch []
