Age of Sail BB cannon manifold system
Discussion in 'Weapons & Pneumatics' started by JClayborn, Dec 4, 2010.
  1. JClayborn
    JClayborn New Member
    I've been playing with a firing system for cannons for Age of Sail ships on a 1/48 scale. On this scale 32 pounders would be about the size of a .177 bb. Basically I've got 5 cannons daisy-chained together that work off of a standard pellet gun C02 cartridge. It seems to work okay and it has a slight "ripple" effect as the pressure travels down the tube. The problem is that those small canisters dont provide a lot of shots. Also, the way that I have the ammo feed set up currently the guns only carry about 12-15 rounds of ammo before they're out. I'm trying to figure out how to bolster the pressure in the system without rupturing the lines and make a single-hopper system that loads all (or at least more than one) gun simultaneously. Anyone who's good with pressure systems who would like to help, please contact me at: Johnathan.clayborn@gmail.com. Thanks!
    are you using motors and pumps on the ships?
  3. jadfer
    If you use a 3.5 oz tank and run your tubing like a fast gun or big gun ship then you will be fine. Are you using solenoids? If not what are you using?
  4. jadfer
    An idea for this would be (will it work?) a combo big/fast fun setup.
    I like fast gun cannons as they are cheap. Cheap is good when looking at 5 to 10 cannons per ship as far as I am concerned.
    The main reason fast gun doesnt use hoppers I am told is that they don't feed at the rate needed for the kind of shooting we do. In my baden I can dumb my 50 shot bow gun in 20 secs or less.
    So either use 4 or 5 fast guns per side with 75 or 100 round magazines OR use a big gun ammo hopper in place of the standard fast gun magazine. With a reload time of 4-8 seconds jamming shouldnt be an issue. We can always add a small vibrating motor to the ammo hopper to keep them from blocking the magazine or sticking in the hopper.
    I suppose that we can use advanced tech to control the shooting. Lets say whenever the ship heals to a certain point the guns will be disabled until it returns to a safe position. This can be done with a small micro-controller.
    Any thoughts so far?
