Air Resevoir
Discussion in 'Weapons & Pneumatics' started by tgalx3, Mar 1, 2025.
  1. tgalx3
    tgalx3 Admiral (Supporter)
    Snohomish, WA
    I want to rebuild my air reservoir for my twin sterns.
    I was a planning on using 3/4" copper tubing but am unsure of the length.
    Should I also make a reservoir for each gun or make one big one and then feed each gun from the one reservoir?
  2. Commodore
    Commodore Well-Known Member
    Sunny TX
    You may like to take a look at my Bismarck page for inspiration.
    https://www.scrapcombatships.com/commodore/warships/bismarck.html
    I will say that the tanks in my Bismarck are probably overkill - 3/4" pipe about 3" long should be more than sufficient. But as some have said, "Nothing exceeds like excess".
    Also, given you'll only be running duals, the simple fact of the matter is that if you put a splitter on the regulator and run a separate 1/4" hose from the regulator to the solenoids, that will probably be sufficient volume to make you happy.
    Which is to say: A lot of what you see are relics from a past where we were using less optimal gases, and regulators which did not keep up with demand effectively.
  3. tgalx3
    Snohomish, WA
    I got about 10” (could make it 12”) between the solenoids and the regulator. Do you think that length of hose would be long enough?
  4. Beaver
    What regulator and size bottle?
  5. tgalx3
    Snohomish, WA
    10oz bottle. Not sure the name it’s the heavy truck regulator
  6. Beaver
    I would recommend tanks. I had duels setup on a BC reg with no tanks and the results were not all they could be even with lengths of hose.
    I use spent 16g capsules as tanks.
  7. tgalx3
    Snohomish, WA
    with your setup, did you use one tank per gun or one large one for both?
  8. bsgkid117
    On all the boats I've ever accumulator tanked, you ideally want one tank per gun with check valves so the guns don't rob each other. Without check valves, the system is going to "share" regardless of what you do. I'll let others chime in, but this has been my methodology.
  9. tgalx3
    Snohomish, WA
    What check valve are you using?
  10. bsgkid117
    Some variation of this MJCV-1AB
    You can get them in different gender combinations for your specific application, helps cut down on the number of fittings required.
    I used to buy them with clippard's own AVT series air volume tanks for accumulators, they had female threads built in, so you could get a Female -> Male check valve that would thread right in and your air fitting would thread right into the input side of the check valve...made a very clean setup.
  11. tgalx3
    Snohomish, WA
    Alright, Im going with tanks. So back to my original question. I was thinking 3/4" diameter but it seems like 1/2" would be fine. What length should I go for? Or what is the math calculation to figure out the length?
  12. bsgkid117
    You're looking for the internal volume of a cylinder. Volume of a Cylinder Calculator
    I used 2 cubic inch per cannon, I think @Kevin P. has a specific size he normally goes for too.
  13. tgalx3
    Snohomish, WA
    cool 2 cubic inches, is what I was looking for.
  14. tgalx3
    Snohomish, WA
    This seem about right?
  15. bsgkid117
    I'm no math expert, but that seems roughly correct? If the calculator says its good lol I just did the math on my own and got roughly that.
  16. tgalx3
    Snohomish, WA
    I tried working backwards and got a different answer. Not sure why...
    2 = H * Pi * (0.75/2)^2
    This gave me a height of 4.5 which is very different than the calculator.
  17. Kevin P.
    You entered diameter instead of radius (0.375). I usually used 1 cubic inch per gun, which comes out to 2-2.5” long with 3/4” ID.
    here’s a link to the clippard tanks
    https://www.airlinehyd.com/product/CLIPPARD-AVT-12-1/1302725
    In the past, when considering the costs for pipe, end caps, fittings, effort/leaks, the clippard tanks were a better choice for me
    Iunnrais and bsgkid117 like this.
  18. Iunnrais
    Iunnrais Active Member
    Texas
    Ahh yes leaks. Soldered tanks give the gift of emergency torchwork at Nats. :) Experienced several times over the years.
  19. Kotori87
    don't forget to consider where the air accumulator tanks will be placed. 2cu.in. is an excellent target size if you have the space and weight available. The ones on my predreads ended up somewhat smaller due to size limitations.
    tgalx3 and bsgkid117 like this.
