An Interesting Airgun Design
Discussion in 'Weapons & Pneumatics' started by TorpCruiser, Oct 28, 2022.
  1. TorpCruiser
    TorpCruiser Active Member
    Everett, WA
    Panzer likes this.
  2. JustinScott
    JustinScott Well-Known Member
    It’s interesting. It’s like a hybrid between fast and big gun tech.
    I’m not sure what the advantage is of that design over the fast gun o-ring + interrupter.
    - You don’t need to buy a clipboard valve, which is nice.
    Downsides..
    I think it would be as lossy as big gun, since it has no o-ring to build pressure, plus the air escapes for one full service rotation.
    The valve is now a custom part which can go wrong.
  3. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
    Those are a lot bigger than what we use. Just replacing a solenoid valve with a motor and gearbox to strike a pin valve.
    We now have designs that can fit a full 1.5U canon inside a barbette.
    JustinScott likes this.
  4. JustinScott
    so like… they should be stealing from us.
  5. darkapollo
    Carlisle PA
    Different applications lead to differences in design requirements.
  6. Kotori87
    It looks more closely related to a paintball cannon in terms of operations, except it uses a spring driven striker to fire. And a motor to cycle the breech and charge the spring. No regulator that I could see, and it needed a combination of gravity and spring feed to load. It looks like they're in Europe, so they may have to use airsoft pellets due to laws.
    I don't think I would use one on any of my ships, but it is a novel solution to the challenge.
