any battlers in northern minnesota or arizona
Discussion in 'General' started by raidernation, Mar 8, 2012.
  1. raidernation
    raidernation Member
    we are from minnesota and when we come back to the states would like to try to find some battlers there and we will be moving to arizona so looking to kinda feel the waters on battler groups since i couldnt find anything that said were battlers were from or at
  2. NickMyers
    Port Polar Bear is in MN. Not sure what their member spread is, but in this hobby we all expect to spend some time driving I think.
  3. raidernation
    raidernation Member
    yes totally understandable thanks for the help
  4. jadfer
    www.portpolarbear.com
    they have a larger MWCI club than most. Bob is the guy you want to talk to. I will tell him to check this thread.
  5. moose421
    moose421 Member
    I am from cental Wisconsin and are a member of Port Polar Bear. We have on a poor turn out day a least 6 battlers. Bob H. is the guy that you want to talk to. He runs our local club. This weekend he is at the Brewhaha but he might check in. His user name is Bob. His avatar is a bear head.
    Any thing I can help you, I will.
    Thanks
    Kim
  6. raidernation
    raidernation Member
    sweet thanks guys i got ahold of him and he gave me some really good advise i am now torn between two boat the houston and the des moines and i will probably be joining when i do return to the states of course if that is ok with him and the group thanks so much for all your help
  7. crzyhawk
    I think you'd probably be best served by a Northampton (Houston). Strike sells a superstructure for it, so in the end there would be less fabrication then with the Des Moines. Also, with only twins instead of likely triples, the gun plumbing would be easier to set up and configure.
  8. raidernation
    raidernation Member
    awesome thanks so much for the help that's really the push i needed because there are just so many choices
