Anyone know where to find Impellers for pumps?
Discussion in 'General' started by themackster2, Apr 21, 2009.
  1. themackster2
    themackster2 New Member
    Hey all,
    Doing some pre-season work on my gear and noticed that the tiny set screw
    is stripped and useless on my Battlers pump.
    Pump spins fine, does nothing!
    This makes the third time since I started last fall that I've seen problems with
    a crappy metal set screw inset in plastic impeller. The impeller itself is in great
    shape, but useless without a functioning set screw which I'm not sure I'll be able
    to safely remove without damaging the weak plastic threads inside the impeller.
    Does anyone know of a source for metal replacement impellers, or at least for
    plastic impellers with a metal collar? I don't really want to order another cheaply
    made plastic one from Battlers (at $9.50 USD) and end up replacing it later due to
    setscrew or plastic thread failing.
    Or, does anyone know another source for pre-built pumps with metal impellers?
    P.S.- Dammit! I think I just lost/misplaced the impeller while I was working on tuning
    up my guns earlier. The pump is sitting there but no impeller.
    Mack
  2. Chris Easterbrook
    You just might have to order one know Mack.
  3. Kotori87
    I have seen people try casting their impellers with a metal collar and setscrew built in, but I don't remember how that worked. Another option is to make your own, using sheet brass and a soldering torch. Until someone started making decent cast impellers, some people used "penny pumps" that were copper pennies soldered or superglued to collars and brass impeller blades. If you have a mill, you can make one out of solid aluminum. If you have a CNC mill, you can make a nice one out of solid aluminum. You could also try casting a threaded insert into your impeller, instead of a collar.
  4. themackster2
    KK, thanks for the replies. I found the impeller sitting on top the servo boxes
    and managed to remove the old set screw and replace it with a new one.
    It seems to be holding so I should be good for now, just lucky I didn't damage
    the plastic threads.
    I think I will try and make my own metal impellers, using the locking collars we put
    on the prop shafts to lock them into place. If I can solder one of the collars to a metal
    plate that will give me the metal-on-metal reliability I'm looking for and give me my center
    anchor point for the soldered on impeller blades too.
    ...always more things to distract me.
  5. GregMcFadden
    I used to make pumps and tugboat has the molds. I casted in place a metal ring with the set screw in it so that the plastic did not take the load. I believe that BC also switched to that after one too many impellers crapped out due to plastic threads.
    If you do cast the impeller, you can use a suitably modified shaft collar of the appropriate size as the cast in insert. Simply dremel in a cris cross pattern into the sides so that the insert can neither slip nor spin (I put my inserts at one end of the impeller, hence the slipout provisions) and insert a long fully threaded screw into the collar through the side of the mold. Cast plastic. Remove screw (I hope you used ample release agent) remove impeller from mold, and put in stainless steel setscrew.
    -Greg
  6. Powder Monkey
    Have the same problem with the set screw for BC rudder gears they sent me a new one but it did the same thing so I just ca them in place worry about it when I have to remove them hopefully never :confused:
    I had issues with the impeller from BC like that. The trick is not to overtighten it.
  8. phill
    phill Active Member
    Set screws can be ordered from Small Parts. Choose the thread and choose the length. I bought a variety and supply the entire club.
  9. Powder Monkey
    SO WOULD GOING WITH THE NEXT SIZE UP WORK IN A STRIPED GEAR OR WPOULD IT BE TO WEEK
  10. Evil Joker
    Evil Joker Member
    get longer ones and put um in when you get it.also works on striped ones
  11. JohnmCA72
    JohnmCA72 Member
    If the plastic is thoroughly stripped, I'd drill out & tap a new hole in a larger size, TBD by how much oversize you need to drill it.
    I'd also switch to a longer setscrew. That will get you more holding power for a given torque.
    Don't over-tighten & use thread-lock, CA, etc. Don't get any into/onto the shaft, pump housing, etc.
    I'd be wary of casting with an embedded shaft collar. That might throw the whole assembly out of balance.
    JM
  12. GregMcFadden
    It works fine John. It throws it less out of balance than having one long metal setscrew.
