Arizona firing speed
Discussion in 'Weapons & Pneumatics' started by U.S.S. Arazona, Apr 26, 2013.
  1. U.S.S. Arazona
    U.S.S. Arazona Active Member
    Does any one know the firing speed of an arizona type cannon? I'm thinking about making a modified Arizona to use in treaty. My only consern is that I'm not sure if it will fire fast enough.
  2. mike5334
    Should work fine with treaty's 2 rounds per second limit.
  3. U.S.S. Arazona
    Thanks, I'm going to try a cheap Arizona design to see if I can get it to work. I'll show the results of the testing once I get a bottle to fit BC's regulator.
