Baltimore Superstructure 1.2
Heavy cruiser superstructure
  1. rcengr
    absolutek and Nibbles1 like this.
  2. Julian Barbera
    Julian Barbera Active Member
    SF Bay
    Nice work! It makes me want a Baltimore.
  3. Nibbles1
    Nibbles1 Well-Known Member
    Orinda, CA
    Nice I’m tempted too
  4. Nate G
    Nate G Well-Known Member
    Bradford, PA
    Interesting. this is the class of cruiser that one of my patients is one of 2 surviving WW2 sailors from. I do not see that anyone makes a hull. If worng, please enlighten me. Is this one of your available laser cut CAD kits???
  5. Nibbles1
    Orinda, CA
  6. Nate G
    Bradford, PA
    Thanks. I see that. I will reach out to rcengr first to see what he has.
  7. rcengr
    I will eventually be selling laser cut Baltimore eventually, but I don't have the materials right now. I definitely won't be offended if you buy from Modelshipsahoy. If you prefer wood over fiberglass, I might have them available in a month or two.
    Nate G likes this.
  8. Nibbles1
    Orinda, CA
    @rcengr quick question:
    On the 40 mm quad bofors, how do you get them to print the barrels? Is there something I'm missing?
    Thanks,
    Sammy
  9. rcengr
    You do need to print the Bofors with supports. The slicer should just support the barrels, not put it any place else. Depending on your printer, it may not reliably print the barrels - I can do it, others within in my club can't. Good luck.
    Nibbles1 likes this.
  10. Nate G
    Bradford, PA
    Thanks. I prefer fiberglass butwould try a wood hull and know they are quite sturdy. Esp after building a Golo kit. Love that one. Given the time, i will get the MSA hull. Danke.
  11. pba
    pba Active Member
    dayton
    Look in the pictures and video section under 3 new ships .You will see a close up of the Toledo a baltimore class ship with the rcengr bofers and superstructer
  12. rcengr
  13. rcengr
    I corrected the 06 level, but I was unable to find an error in the 05 level. I did find a similar error in the aft 03 level, so I corrected that too.
    I do appreciate you bringing the errors to my attention so that I could correct them.
  14. rcengr
