Battery Charging Bank
Discussion in 'Electrical & Radio' started by tgalx3, Jul 5, 2023.
  1. tgalx3
    tgalx3 Admiral (Supporter)
    Snohomish, WA
    I see myself amassing a large amount of LiPo batteries. I would like build a charging bank to charge multiple LiPos at once.
    Can I even do that with the signal wire? All the batteries are 11.1 V but would be different MaH.
  2. bsgkid117
    Not without potentially unbalancing the cells of each battery.
    You don't need to balance charge every time you charge, but I do just to be safe.
  3. tgalx3
    Snohomish, WA
    I have been doing thus far to be safe too.
    ingiess I’ll be getting multiple chargers then.
  4. Kotori87
    Multiple single chargers is the best solution if you have space. If you have a limited budget, you can get one charger at a time several times until you have sufficient charging capacity. If space is an issue (ie traveling to Nats) and you can afford the up-front cost, then a multi-charger is the preferred. I have a Venom Pro Quad (4 chargers in one unit) that takes up much less space than four separate chargers.
    I have also seen large banks of chargers for NiMH. Just eight dumb trickle-chargers and a really big power strip. Not that we see much NiMH in Fast Gun, but the chemistry is still popular in Big Gun.
  5. tgalx3
    Snohomish, WA
    That charger is a beast! Maybe Santa will get it for me for Christmas. Lol
  6. bsgkid117
    I have a few of the Venom Pro Duo's and I just recently bought an ISDT K4 because the "Big Freaking Batterys" that run my largest boats take too long to charge on the Venoms. Needed something that could push 20+ amps per side.
