Well atleast I know She can take one hell of a punishment I had almost every BB he fired rolling around in my hull LOL she would have stayed up longer if she didnt roll dam cruiser even still she made one last defiant shot at Big Mamie from her side before she went down []
Wow, monk, she definetly took a beating, but she did well. Really good picture, and better luck next time
oh, and dont forget to look into getting a lower center of gravity, or you will continue to roll your way to the bottom of the pond at NATS
Pssssst, Luke.... use foam for the super structure....................there are some more periods........
still, i woulda thought that they did better then that. i mean i know long and thin ships roll easier, but i didnt think it was that bad. But then again ive never been to a battle, so i wouldnt really know. and thankx gettysburg, Ive always had an obcession about puncuation, the more the merrier.
.say.getty.thanks.for.the.tip.but.mine.is.all.balsa.hollowed.out.after.the.first.level.that.is.plywood.it.is.pretty.light.[^]
I'm starting to see spots...see spot run...run spot run.. Swampy used some sort of foam packing for his s/s on his cruiser kits. I never found the supplier? Ding fries are done.....
My favorite picture is her laying on the bottom, right where a Allied cruiser should be. [^] JK, she looks good on the water, but does look a little tipsy, but what to do, cruisers have that problem.
just testing the bottom conditions for the axis side we dont want it to be to harsh janeva convention and all []
