BC Rudder gears
Discussion in 'General' started by Powder Monkey, May 31, 2008.
  1. Powder Monkey
    BC Rudder gears any Tips on stopping the over throw stock set up gives me 65 degrees of turn cool water brakes [:p]
  2. SnipeHunter
    Do you have adjustable endpoints on your radio?
    Yeah, what he said!
  4. Powder Monkey
    not sur probably I have a spektrum and I havent realy played with it yet [:p] i'm used to the old meteal box[8D]
    You have the necessary adjustments, Monk. The mexican guy who brought you your radio (named Manuel) can explain how to use the radio's functions ;)
  6. Gettysburg114th
    Tug, Now that, is a good one...
  7. Powder Monkey
    [:0] yea yea yea right after I stop for directions I will read the dame destructions like I have had time [|)]
  8. Powder Monkey
    Okay I read them I’m not very good at japans but I got thru it and it worked in one direction but not the other [V]
  9. GregMcFadden
    you have to adjust the end points for both ends, as it does not force you to be symmetric. you may have to hold the stick a bit to the side you want to adjust to adjust that end point
  10. Powder Monkey
    [|)][:0][:p] ill try it than the hammer comes out [;)]
  11. wrenow
    wrenow RIP
    Of course servolink sprockets and their tiny plastic chain work well in this application, too, and the location of the servo is not as tricky. One source is Servo City.Visit this site
    Additional sources are on the NTXBG web site, I believe.
    Cheers,
  12. ProfessorChaos
    ProfessorChaos Active Member
    Centerton, AR
    I used the servolink chain in my Yamato for years. Works wonderfully.
  13. admiraljkb
    admiraljkb Active Member
    I've pretty much standardized on servolink for driving the rudder as well starting with Dallas years ago. Allows for a better fine tuning of rudder throw, and an easy symmetrical throw as well.
  14. Powder Monkey
    The Metal or plastic chain ?
  15. admiraljkb
    The plastic (delrin I think).
  16. Powder Monkey
    no problem with chain snapping ?
  17. admiraljkb
    On a Rudder? :) No. There are folks in NTXBG that also use it to attach their motors to the propshafts without too much issue. It's stronger than you think.
  18. Powder Monkey
    My son had his first trouble this weekend while I was shaking down the Boston he crossed my bow as I was looking at my dog at edge of the pool and well can you say speed bump and my bow rolled him and hit his ruder while he was trying evasive maneuvers and the chain snapped as my hull drove into the ruder in the opposite direction but I put it back together and had no other troubles [^]
  19. EricMA
    EricMA Member
    Well if you didn't use your ships as a demolition derby that wouldn't happen. try shooting it next time and quit paying attention to the damn dog.
  20. admiraljkb
    ah, Speed Bump! That I understand! See my Espana as a Speed Bump for a Richelieu: http://www.youtube.com/watch?v=oA3IY6N5Ex4
