Big gun bb cannons
Discussion in 'General' started by uss Johnston 557, Apr 26, 2013.
  1. uss Johnston 557
    uss Johnston 557 Member
    Where can I get Big gun bb cannons.?
  2. jstod
    as of right now yo cannot. they have to be built specially. but a fast gun cannon may work for what you want to do
  3. uss Johnston 557
    I can use a fast gun cannon in a big gun club ?!:woot:
  4. jstod
    yes but the firing speed rules still apply.
  5. uss Johnston 557
    How do you set the fireing speed?
  6. DarrenScott
    Personally, I use a custom-built 555-based timer to regulate my firing rate...but others just count, (sometimes very quickly).
  7. jstod
    the cannons are set up so that you pull the "trigger" aka which ever button on your controller you designated to do so, once and it fires once. each caliber has a specific time limit that the operator must wait before his/her next trigger pull. The problem with fast gun cannons, based on my limited knowledge and research into them, is they can occasionally spurt fire or fire more then one ball at a time. This is illegal in big gun. The fast gunners on here can better explain how to prevent this and how to set up your cannons.
  8. jstod
    Darren, I am interested in your built in timer. do you have a thread on here that explains it?
  9. uss Johnston 557
    How does the trigger system work ? Do you use a servo or something ?
  10. Tugboat
    Some people use a servo that presses on a manually-operated poppet valve.
  11. jstod
    Have you ever seen an actual one of these things working in person or pictures of how they are supposed to work? (not you tug we all know you have :p)
  12. Tugboat
    Glad you cleared that up! I laughed and snorted a mouthful of water out my nose, near enough :)
  13. wrenow
    wrenow RIP
    Also, you may need to de-tweak it a bit to meat the penetration/velocity rules. Also not legal in AUSBG - they start at 3/16" I believe.
  14. wrenow
    wrenow RIP
    By the way, it appears (only partially tested, as the radio is not in the wild yet), but you may be able to set the firing interval on the transmitter with a FRSky Taranis, once they come out.
    You could also make an interval enforcement out of a Picaxe 08M (or now, the newer, better, faster, cheaper, 08M2), probably easier than with a 555. I use the www.techsupplies.co.uk/epages/Store.sf/en_GB/ Picaxe 3-4 servo controller board in my fire control Assistant to take direction frm a Master turret, and range from depression, and control signal for slave, and, if the slave can engage the Master target, does so automatically. If it cannot, it returns to its commanded position. This is a general purpose microprocessor, cheap and easy to work with, and could easily be set up as a fire control interrupter. Programs in BASIC (not C), aied at young students, not engineers, and the programming interface is free to download and play with. it also has a very active forum for help.
    Nice thing, the circuit board is already designed. A little soldering, drop in the program, and done.
    If building into the TX, probably easy as well, but just use the smaller, cheaper, www.techsupplies.co.uk/epages/Store.sf/en_GB/ Axe 231 module could do the 5v switching at the TX fire button.
    Probably mechanical ways to do so as well.
    However most people just fire the gun, count "one mississippi, 2 mississipi for however many mississipis they need" to themselves, then fire again.
    I belive someone over in the AUSBG also has developed an interval enforcer that is (or was) for sale.
    Cheers,
  15. SnipeHunter
    BC sells firing boards that can enforce ROF limitations, currently they only have boards for treaty (2 shots/sec) but if you need a different rate for Big Gun they can get those for you as well.
  16. Knight4hire
    Knight4hire Active Member
    I am in a BIG GUNS club and my little Liberty ship is armed with a single fast guns BB cannon. My firing servo is a little on the small side so I have to level it away from the fire button then to the fire button to make it fire. So there is plenty of lag between shots.
