Big gun cannon
Discussion in 'Weapons & Pneumatics' started by indie2002uk, Dec 1, 2019.
  1. indie2002uk
    indie2002uk Member
    Western Australia
    Is there plans for big gun cannons that can only be made by hand tools only?
    Selley likes this.
  2. Kotori87
    You can piece together a non-rotating Big Gun cannon using a few Clippard air parts. a MAT-2 accumulator, an MJV-2 main valve, an MPA-3 actuator, and a MAV-3 firing button. You'd also need an appropriately sized brass T-fitting for your desired caliber. For 7/32" balls you'd want 5/16 compression fittings on the top and side, and for 1/4" balls you'd want 3/8 compression fittings on the top and side. Either way, you'd need 1/8NPT on the bottom to screw into the MJV-2 valve.
    Keep in mind, that would produce a single-barrel, non-rotating Big Gun cannon. Multiple barrels can be achieved by daisy-chaining several of these together. If you want a rotating multi-barrel cannon like most battleships use, you'll need access to either a 3d printer or a drill press, band saw, and lathe.
  3. indie2002uk
    indie2002uk Member
    Western Australia
    Thanks, have band saw out of that list and scroll saw. I’m thinking about the a 3d printer it’s just cost. I’m a father of 4 on a pension after having to give up work due to very sick kids. So every time I almost save up the pennies, something else take priority.
    My son who’s 13 already built his Dorsetshire is awaiting cannons and he’s already started on his Montana
    Selley likes this.
  4. nmmichris
    nmmichris Member
    Fredericksburg virginia
    Sooo. I've done a good deal of reading on cannon designs for big gun warships. I am curious if there is a new design that people are moving towards or are the Indians style guns still used more often. I've got a design I created based on old plans from strike models but just trying to see what's new that will be better on space. Any thoughts or plans appreciated
  5. Nibbles1
    Nibbles1 Well-Known Member
    Orinda, CA
    If you are considering a 3d printer, I would say go Prusa.
    indie2002uk likes this.
  6. Julian Barbera
    Julian Barbera Active Member
    SF Bay
    Prusa machines are extraordinarily high quality, but very expensive(compared to low-cost, Chinese alternative.). The curret recommended budget machine is currently the Ender 3, the kit retails for about 180 USD, and often has big sales.
  7. absolutek
    SeeMeCNC Rostock or Artemis printers are good also.
  8. indie2002uk
    indie2002uk Member
    Western Australia
    Why purse over creality
  9. Julian Barbera
    SF Bay
    Prusa makes incredibly high quality printers, often called the best Creality makes good printers.
  10. Nibbles1
    Orinda, CA
    Okay yeah Prusa isn't that cheap but is great. I go a Prusa I3MK3S kit for 300 less than the ready one.
  11. Julian Barbera
    SF Bay
    $250 less than the $999 dollar one.
  12. Nibbles1
    Orinda, CA
    Sorry I thought it was 300. Still a lot though
  13. Selley
    Selley Active Member
    Butler, W.A
    Im confused
  14. Nibbles1
    Orinda, CA
    We are talking about 3D printers. They are really useful
  15. Selley
    Butler, W.A
    I was lost on the price
  16. Julian Barbera
    SF Bay
    Prusa i3 Mk3s - assembled $999 USD
    Prusa i3 Mk3s - Kit $749 USD
    Creality Ender 3 - Kit $180 USD
  17. Selley
    Butler, W.A
    Thanks
