Bismarck Turning Radius
Discussion in 'Propulsion' started by tgalx3, May 7, 2023.
  1. tgalx3
    tgalx3 Admiral (Supporter)
    Snohomish, WA
    I’m finally getting started on building my Bismarck. We battle in a smaller pond so I need the turning radius on this beast to be as tight as possible. It’s a 1/144 scale fast gun model.
    What are all the legal tricks I can do with the rudder to get as tight of turning radius as possible?
  2. Kevin P.
  3. Commodore
    Commodore Well-Known Member
    Sunny TX
    Are you sure pot metal (zinc) is a good enough material for battleship props? I'd be concerned about bending/breaking.
    Also - hey, no love for my Bismarck??? Boo!
    https://www.scrapcombatships.com/commodore/warships/bismarck.html
    BTW, shh, don't tell anybody but I was sandbagging it for that video, the Bismarck will actually spin on its center - don't tell anyone!
  4. SnipeHunter
    Boatmeister and tgalx3 like this.
  5. tgalx3
    Snohomish, WA
    Well share the secret. Lol
  6. SnipeHunter
  7. Kevin P.
    They seem in the ballpark with other options, shown next to 1.75” shapeways and protean design
    Here is 2” next to shapeways 2”
    center of the blade thickness is slightly less (0.04” vs 0.05”), so don’t try to crabwalk the stern across a boat ramp, but 15% of cost of shapeways ($9.7 vs $63 for 2”). No run time on my boats yet because new builds have slowed with life, and I have some pre-fire prop shop props still to use
  8. tgalx3
    Snohomish, WA
    It looks like you are getting more thrust on the turns to whip it around. Do you have different settings to change the speed on the turns?
  9. GregMcFadden
    Look closely at the rudder shape and how they are set up to turn. It is the end result of that type of tuning the rudder shape and interaction
  10. tgalx3
    Snohomish, WA
    So its just my imagination?
  11. SnipeHunter
    Nope, just your imagination. A system such as you describe would most likely run afoul of:
    D. RUDDERS
    1. Only rudders shall be used to steer ships. No "turning motors" or other systems may be used to assist in turning.
    There isn't a secret or some hidden trick to it. A ton of people have inspected that setup, nothing hidden. Heck it's not even using some of the other stuff out there like end plates on the rudders, so in theory it might even be able to be "improved".
  12. tgalx3
    Snohomish, WA
    Haha. Improved. You set the bar high.
  13. Beaver
    With our recent rule change giving ships greater rudder area it's been much easier to make a ship turn well. My Jean Bart will spin and it is a duel prop, single rudder boat. It shouldn't be too hard to make a Bismarck turn that well.
    View: https://youtu.be/jgIZe_z3VUA
    Panzer, notSoGnarly and Boatmeister like this.
