bismark and tirpitz build
Discussion in 'Warship Builds' started by drift zamurai, Apr 13, 2012.
  1. drift zamurai
    drift zamurai New Member
    hey guys here is me and my fathers build...
    here is my layout with new rib locations 10 mm ribs 76 mm apart. as you can see in the pic the new ribs ar in different spots then where the kit puts them lol. This made things a little difficult but this is what i came up with. drew up the new ribs on the rib template. there are 2 ribs on the original rib template not used to make up the new ribs. with any luck my drawn ribs will be good haha
  2. jadfer
    What scale are you building to? That looks like it might be less than 63 inches.
  3. Jay Jennings
    Yeah Lloyd,
    Bismarck is supposed to be 68 2/3 inches long by 9 5/6 inches at the beam.
    Is that a 30 cm ruler on the stern of the plans?
    It might just be a trick of the picture but it looks smaller than it should.
  4. drift zamurai
    hey its in 1 144 scale
  5. Jay Jennings
    Good,
    It would suck to build a ship and THEN find out it is in the wrong scale!!
  6. jstod
    were did you get you plans?
  7. Jay Jennings
    you can get plans at Strikemodels.com
  8. gunsnrosesx
    gunsnrosesx Member
    have fun with the build i did, and its even better you have someone building another with you that way you can help each other. keep us posted
  9. drift zamurai
    the plans are from strike models and the ruler is in inches haha the only problom with the plans are that there are so meny abreviations on the plans and i dont know what any of them are, I called strike models and they dont know what they are nither and there is no legend for them:(
  10. NickMyers
    Post some pictures of the marks in question, we might be able to help. Some of the guys here have been staring at plans for 30+ years now I think.
  11. GregMcFadden
    Also, if you are still having trouble, I've got a copy of the anatomy of the ship series on the bizmarck and some detailed german plans drafted in ~1990 I think (I don't read german) that may help clarify what is going on.
    What are the abbreviations on thh plans? I have the same plans as you.
  13. gunsnrosesx
    gunsnrosesx Member
    haha i never noticed them when i was building mine, this thread just pointed them out to me, now im wondering what they are.
  14. drift zamurai
    lol ya there beside every part on the plans. a nother thing i noticed is on the one sheet of plans i have where the rib template is it shows the side view of the fron and one of the rear and in the middle it looks like it would be the middle rib so rib 8 on the plans, its not to scale its almost and inch taller the top half of the rib lines up though so i have no idea. mabe one of you guys know i have a pic of it above its the sheet thats hung on the wall
    That pic can you take a seperate picture of it but closer so we can see what it is your referring to exactly? I can't see the plan detail from that one pic you have already posted . Is it the pic with the plan on the table and on the wall? , if so take a closer pic of the plan on the wall.
  16. drift zamurai
    haha sorry, ya i will post a pic up asap i go down stairs now and take one
  17. drift zamurai
    ok guys,
    here is a pic of rib 8 widest part of the ship, waying on the side view of the hull. you notice how the hight is perfict.:)
    here is the other pic menchined befor of the front and the rear half of the ship with im gessing center rim (8)
    and here is the 2 ribs compaired
  18. CURT
    Those are just identifications of the sections using numbers and letters to identify the different sections. Usually the letters indicate the Frame and the numbers identify the rib. I believe the sections or frames are lettered followed by the number of the rib. A frame rib 1 A frame Rib 12 . I think it's something like that. Don't worry about what it means just know that it clearly marks a section'
  19. drift zamurai
    ok sounds good i will just ignore it for now, i will now start on re cutting out al the templates with the new ribs i drew up, hopfuly it will be ok. :cool: i know its for from now but will 2 little trailer brake batterys work 12 v 5mah batterys work for theys ships?
  20. CURT
    There are lots of Bismarck's on this forum to use for references so your in good hands there.
