Brooklyn Hull
Discussion in 'Construction' started by Bryan, Oct 10, 2008.
  1. Bryan
    Bryan Member
    Hello!
    I am just finishing up a plug for a
    (under IRCWCC) USN Brooklyn 'A'.
    Class 3, 3 Unit Shp
    I will be making a fiberglass mold of this
    to enable me to pull more from it. Am I
    waisting my time (I could not find
    fiberglass hull of these for sale anywhere)
    or is this a good Idea. I am gaining more
    experience with my molding and mold making.
    Later I could offer some to some of you if
    they meet my quality standards as i do not want
    to make something for someone that is not
    what I want to sail. I currently have 3 molds
    and Brooklyn will be my forth, am always
    looking for another project.
    let me know if you can buy Brooklyn anywhere
    (mine will actually be Savannah when completed.)
  2. Buddy
    Buddy Active Member
    Newark Ohio
    HI guy well the Brooklyn is available from Battlers Connection. I have heard of guys makeing them in to Clevelands but I know the bottom part of the hulls is different. A friend of mine and battler are working on makeing a good hull of the Idaho class battleship after the extra bulge was put on, after Pearl Harbor. I would be interested in some help makeing a mold!
    Buddy
  3. Bryan
    Bryan Member
    Where abouts do you live?
    I am in Ontario Canada
    I can try and help through e-mail and here but best would be in person.
    First part is making a "perfect" hull shape of what you want to mold
    remembering that you will loose about 1% when making mold and then 1%
    when taking hulls from that mold, this is due to the properties of
    fiber glass molding. then also leave room for the 1/32" balsa skin.
    That is the hard part, once you have a good sized and shaped plug
    and it is as smooth as you can make it you can start waxing it.
    If you have a fiber glass shop near you get some PARTALL #2 if
    not able to get this get some CARNUBA wax (little more expensive)
    You will want to wax/dry/buff the plug about 10-20 times to make sure
    the surface is really smooth and shinny and has no areas that have any
    pores or rough spots or areas that the mold will lock onto.
    Take a look at what you want to mold, and decide where you want to
    put the mold break line. This will be where you will be taking the
    mold apart to be able to get your part out of the mold. On a hull
    it is generally down the outside center line from bow to stern.
    This parting line needs to be defined by taking some rigid object
    like thick plastic sheet, metal, wood, or cured fiber glass. you
    take this and build up your center parting line about 2"-3" tall off
    the spine off the hull, at the same time you do this to the edge of
    the hull you will be making the first half of the mold of (the clean
    side of your parting line, again with a 2"-3" flange all around it.
    Where you cannot get a perfect fit with your rigid parting line you
    take modeling clay (Non hardening) or plasticine and fill all the
    small gaps to make it a perfect fit, any extra clay is removed so you
    have as close to a perfect fit without any radius at the fit points.
    You now make sure the flanges and everything is also waxed well to
    allow it ro release well.
    Now you build up the half of the hull you have prepeared and make
    your first half of the hull by spraying or brushing on PVA release
    agent (NOT PVA Glue!, Poly Vinal Alcohol) over the waxed areas,
    this should be light coats. once dry be careful not to scratch or rip
    this as it becomes like cling wrap. When dry you mix up a batch of
    tooling gel-coat which is harder than normal gel-coat and more wear
    resistant (And more expensive) and paint or spray this onto the mold
    until you get a good coverage, this is best if the gel-coat was mixed
    with a dark color pigment (like black) so air bubbles will be easier
    to see when molding parts.let this dry till little tacky but finger
    comes away clean. then add first layer of fiberglass matt and wet
    it out with mixed resin, then keep adding layers and re-enforcing
    corners and large flat areas, after a few layers you can add some
    wooden supports for strength or to help you to keep mold flat when
    in use, class right over these and make them part of the structure,
    sealing them in for good. Once you have a thick enough mold you let
    this dry for at least 24 hours then come back and remove your flanges
    and the center parting line you made. Drill in some dints carefully
    into yur center parting line with a large drill but make sure you do
    not go through it you are just making dints that will help line up
    the 2 halves of the mold later.
    Wax this second side of the mold like the first and ensure you wax
    the new parting line and dints you drilled carefully as well as the
    hull top flanges again also. You can now build up the second half of
    the mold just like the first except that the center flange is now
    just the first half of the mold. (And you should not need any clay)
    Let dry for another 24 hours minimum, should be hard everywhere.
    take a small drill (clearance for a 8-32 bolt) and drill some clamping
    holes through both sides of the mold along the center flange fairly
    close to the hull but far enough away so you will easily be able to
    put bolts with washers through them and a nut to hold the mold
    together for use. By doing it now you are sure this is how the molds should line up and it gives you a second way of ensuring the mold
    halves are lines up when you go to mold.
    Now the moment of truth, you carefully try to release your plug from the mold, you are 'breaking' the mold for the first time, pry it
    apart a little and then put a small wedge in it(wood is fine, careful
    not to scratch the mold!) keep doing this all along the joint line
    until one side or the other "pops" off if it is being difficult you
    can try pouring in warm/hot water as this will dissolve some of the
    PVA and make it easier to pop. Once you have the first side off the
    next is easier as you have someplace to pull the plug toward and out
    of the second side. Now once out check the mold and repair any
    defects with resin mix and lots of careful sanding then lots of coats
    of wax. you now have a mold, stand back and ohhh and ahhhh at it, really!
    [:D]
    ok enough of the ohhh and ahhh, back to making hulls
    now you want to use the mold, again clamp it together and then wax
    the heck out of the mold again, for the first few times you will need
    to wax it about 10-15 times, later you can start to reduce this as
    your mold is used more and pulls become easier. Mix up some jel-coat
    and paint or spray this into the waxed mold being careful never to get
    more than 1/8" anywhere as otherwise it can wrinkle on you and you
    will have to take it out and do it again., let this dry or almost dry
    the lay your pre-cut fiberglass mat in the mold and pour your mixed
    resin over the matt and then move it around to get rid of all the bubbles, extra layering should be put around the bow/stern/props/sides
    of the hull to ensure these areas are strong, you have to be careful
    when doing destroyers or light cruisers as they can be weight
    sensitive)again make sure all air bubbles are worked out. When resin
    hardens to just past jelly stage you can trim the extra hanging out of the mold with industrial scissors. now let it dry for 24 hours.
    Now play taps and have a drum roll (in you head if needed) and take
    the bolts out of the joint flange, mark any overhanging mat that still
    needs to be carefully cut off after removing from the mold (use sharpy)
    and then start to get your part out of the mold just like we first did
    for getting the plug out, now you just have to be careful that you do
    not damage the mold or the hull. Now when it comes out, its champain
    time (ok a beer will do) and you have your hull, final trim with a
    dremel tool and cut off wheel and it is done ready for someone to make
    into a combat hull after a careful check by you that nothing is wrong
    with it.
    Always use Resin and Gel-Coat that DO NOT CONTAIN "Air-Dry" or "Wax"
    as these can leave a bad waxy surface and if you need to add layers
    will mean lots of prep to make sure the layers stick to each other.
    Ok hope that helps give you a idea
    br/>So you can see it can take you a good week to make a mold and try the
    first pull, and if its wrong, you start all over.....[:(!]
    Send me a e-mail and I'll get you more answers on specifics, but for now i think I have exceeded my message length maximum and Tuggy may be not so happy with me, good luck!
  4. Bryan
    Bryan Member
    The BC boats are Cleveland Class Boats, (CL-55) and Brooklyn is (CL-40)
    a slightly smaller type of vessel.
    Cleveland CL Brooklyn CL
    Disp 10,000 T 9,700 T
    Length 610'+1" 608.3'
    Width 66'+6" 61.7'
    Speed 32.5 Knt 33.6 knt
    Guns: 12x6" 15x6"
    4x tripple 5x tripple turrets
    12x5" 8x5"
    6x twin 4x twin
    32x40mm ?? Have to check
    8x quad
    So you can see they are close but not quite
    the same ships, profiles slightly different
    depending on actually hull measurements of molded
    hull you could get close to making both I guess.
    but mine is definitely of the Brooklyn (a) if under
    IRCWCC Rules (the narrower one, as I made a boo-boo on the
    plug and it went from the wider version to the narrower version
    (don't ask))[xx(]
    I never want to make a mold of something BC is making
    as I like their hulls and will continue to buy them and why
    should I make something that is already out there.
    [:D]
  5. Buddy
    Buddy Active Member
    Newark Ohio
    Hi I am bad I got them mixed, your right BC makes the Cleveland hull and swampy use to make the Brooklyn.
  6. Bryan
    Bryan Member
    Ja, I was worried that after working on the plug that BC might have
    beaten me to the punch, but all is good, I actually sent Rick a
    note telling him i was making a Brooklyn plug/mold so I'm sure he
    would have let me know if he was making one or had one (At least I
    hope so).[:eek:)]
    I am mainly trying to make some boats and hulls so guys in our local
    area can get on the water fast, I will make a hull, cut/sheet it and
    then add everything to make it float and go with some basic
    superstructure and then they can go to BC and get the guns etc that
    they really want to put in it.[:p]And later on they can go to him
    for bigger or other hulls to get them building their own and learning more.
    I am not out to cut into Ricks business, In fact I will be
    encouraging anyone who gets one of my hulls to go and see him to fill
    it up. Being in Canada the hardest thing to get here is the hulls
    as they are the worst to ship, and can take some time, if i can get
    someone a ship that they just have to finish up and make their-own
    then they will be more likely to stay in the hobby and it will be
    much faster to get them on the water and let them punch holes with
    their own boat as opposed to the club boats.[:)]
    And as far as mistaking hulls, no problem I do the same thing all the
    time to, as someone will name their boat and its not the class name
    from the rules so I go scrambling and make mistakes all the time
    too, so you see you are not alone, good luck and have fun![:D]
  7. Buddy
    Buddy Active Member
    Newark Ohio
    Bryan that helps a lot, I was not sur ejust what we were getting in to. I live in ohio so it is a ways other wise I would look you up for some help!Still might see about some help with this.
  8. Bob Pottle
    Bryan,
    Eric Broderick, a former NABS member who sells convoy and merchant raider hulls, battled with a USS Brooklyn for a few years. I think the hull was semi-scale, based only on side and top views. Only one hull was made from his mold.
  9. Bryan
    Bryan Member
    Ok I think mine is pretty good, it is the norrower "A" version but I think it is ok, looks like ones I have seen wooden hulls of so I think
    I will be ok, now off to make a nice mold.
  10. MotoPhoto
    MotoPhoto Member
    Does anyone know if Eric Broderick still sells hulls? I couldn't find any online information about him other than an old email address.
  11. Bob Pottle
    Eric is a member of RCNC and still makes hulls. His handle is Canuck100a. You can email him directly from the Members list.
    Bob P.
  12. crzyhawk
    If you're looking for another cruiser project, here are a couple of ideas I'd like to see someone produce, which I think would also be good ships:
    Soviet Kirov class cruiser
    German Nurnburg class cruiser
    USN Portland class cruiser
    RN Southampton class cruiser
  13. djranier
    I like the Soviet Kirov class, I also think it would make a good looking ship.
  14. crzyhawk
    Kirov has the advantage of making a sweet big gun torpedo cruiser as well, so there is multi-format appeal.
    Kirov is a good cruiser project.
  16. pba
    pba Active Member
    dayton
    The Chapiev was a super Kirov, and the Sverdlov was a super chapiev about the size of the Des-Moines 3.5 units. BDE has plans for both.
  17. crzyhawk
    Yeah the Chapiev would be nice. Did she carry torpedoes? The sverdlovs are awesome, but given their date of construction I am not sure if they are legal in any format of combat. Did they carry torpedoes?
    Edit: My spelling is terrible!
  18. pba
    pba Active Member
    dayton
    Both carry a bunch of torpedoes
  19. crzyhawk
    They'd be pretty good ships in big gun for sure then I'd guess. Isn't the Sverdlov a little slow for a big gun torpedo cruiser though? IIRC, she was only 33 knots...I'm pretty sure Chapayev and Kirov were in the 36 knot range. Been a while since I looked them up though.
    I'm not sure if Sverdlov is legal technically in Treaty (I certainly would not object to someone building one), but I know it's not legal in the other fast gun clubs. Chapayev and Kirov are both definitely legal for the other fast gun clubs though. Heck if someone showed up with a modern Ticonderoga, I'd vote to let them battle it, provided they followed the rules for units displacement etc. I don't see much reason at all to tell people "no you cant build that".
