Found this at Value Hobby, been buying from Alex for years. Good service and willing to make problems rite. http://www.valuehobby.com/power-systems/speed-controller/electric-car-esc/320a-brushed-car-esc.html Seriously doubt it is actually 320 amp capable though, that would fry those tiny wires haha.
Also found this, http://www.valuehobby.com/power-systems/speed-controller/electric-car-esc/3in1-18096.html Looks like a nice setup for super small boats where space is a big concern.
Here are my questions. Forward and reverse? Can it be set to no brake? Can it be set to 100% reverse? I know the Hobby King ESC can be set to use in our application. The product description for this does not tell me.
If you do that, order a backup (spare) in case no one else is running one and yours fails. Make sure however you wire it, that you make a jumper that will use other connectors so if you borrow anything you will be able to plug and play and not have to solder during the battle
I may do that but I need to know at least that they have reverse before I do as money is super tight at the moment.
Ok, Alex said it has reverse. Not sure about the brake. I will order one and see the next time I need a speed control.
