Buch o' Questions
Discussion in 'Weapons & Pneumatics' started by jamesyoung, Feb 13, 2010.
  1. jamesyoung
    jamesyoung Member
    Is anyone using electronic valves to fire their guns? I've looked through clippards selection, and it a bit too expensive to buy a bunch and play with them. I'm hoping someone else has done that for me. :)
    James
  2. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    For the most part in Fast Guns, clippard valves are rated too low. Our pressure is 150psi. There are other solinoids out there which do work, Kips are most commonly used.
  3. mike5334
    The Clippard Mouse series valves cannot handle the 150 psi pressures we use for very long. But, they will handle less than 100 psi and can be used to actuate air piloted valves for the cannon air.
    Clippard makes a stronger electric solenoid valve that a few people use. I have them in my Richelieu. The downside is they are 12 volt only and do not operate well on 6 volts. My Richelieu has a 12 volt battery just for the 12 volt Clippards.
  4. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    You can get 6 volt coils for the KIPS! Been using them for years. (Maybe they quit making them ;>O ) I haven't had to buy any for at least 5 years.
  5. jamesyoung
    jamesyoung Member
    It looks like KIPS is still around:
    http://www.norgren.com/document_resources/KIP/Valves03.pdf
    Can you still see your model number?
  6. moose421
    moose421 Member
    I'm using 6 volt KIPs. I bought mine from Battlers Connection.
  7. djranier
    The 6v Kips are a special order, BC buys them in larger qty's, to get a lower price.
  8. jamesyoung
    jamesyoung Member
    I'm going to start a new thread on solenoids with a good subject... smack me if I do that again.
