Building surcouf plug
Discussion in 'Construction' started by U571, Apr 27, 2009.
  1. U571
    U571 Member
    I already built the frame, sprayed it with the expading foam and sanded it down to shape, but I'm not completely sure what to do next...help?
  2. eljefe
    eljefe Active Member
    Sounds like a question to ask in the I-400 Hull thread in the Warship Builds section of the forum.
  3. phill
    phill Active Member
    Next step is a thin coat of bondo. Then sand smooth. Repeat until the shape is exactly what you want.
  4. U571
    U571 Member
    thnx, Ive got that done now, do I put the shellac on next?
    Edit: what type of wax should I use?
    Mold release wax
  6. Anachronus
    Would you have any pictures of the build?
