CAD design of Bathurst class corvette for 3D printing
Discussion in 'Digital Design and Fabrication' started by 3DprntrMike, Jan 25, 2016.
  1. 3DprntrMike
    3DprntrMike New Member
    Hi, long time listener first time caller here, Since there is no active club near me this is mostly a design exercise to work on my CAD and 3D printing skills. The ship is a mostly accurate Bathurst class corvette using the AusBG rulebook.
    Reciever,motors servos etc are all modeled on those from my parts bin from various RC cars and helicopters, so they are not always the best choice but what i have on hand.
    So far all the heavy items are below the waterline so as long as the hull has the displacement sea handling shouldnt be too bad and there is still over 1/2 the hull volume left for its pea shooter armament (original vessel had a 3" cannon so it would be useless in combat).
    i will be eventually printing a hull less the windows in PLA on my homebrew printer, which can be done in one piece due to its 460*490*290mm build area (LOA of hull is a hair over 400mm) my printer can print up to 90mm/sec so its an "overnight" print job.
    Luckily the hull is almost done as my PC is starting to stumble while rebuilding the model, and it takes almost 5 hours to slice (with support)
    rcaircraftnut, rcengr and NickMyers like this.
  2. NickMyers
    Nice build volume, mind sharing info/pics about your printer?
    The ship looks good too :D
  3. 3DprntrMike
    Printer was designed and built in a little over 8 months as my university thesis, the original plan was to add milling/engraving capabilities hence the over engineering but i never got around to that. its big its fast and was designed to make large parts (such as automotive bellhousings) using lost PLA casting
    rcaircraftnut and Tugboat like this.
  4. dietzer
    dietzer Admiral (Supporter)
    That's a thing of beauty...
    Well done!
  5. 3DprntrMike
    print took around 9 hours with a failure 1/3 the way through so it was done it two parts and plastic welded together. i need some brass to make the prop and rudder tubes, and to waterproof it befor i can test it out.
  6. NickMyers
    Looking good. Any reason for printing the skin as well?
  7. 3DprntrMike
    i am doing this one to test the fitment of the machinery, once it all works out i will print one in ABS with the windows built in and sheet it as usual.
  8. pbhawkin
    pbhawkin Member
    Mudgee, NSW, Australia
    3DprntMike if you are around check out the conversation (PM) I sent you.
    Peter
  9. 3DprntrMike
    My mabuchi FK130SH motors finally turned up and ive made the motor mount, progress is slow due to my new job. next up is getting the ESC sorted
  10. 3DprntrMike
  11. SteveT44
    If you're running those little motors at 6v, the Vex 29 ESC will work great. Just wire the red and black leads on the Rx side directly to your battery.
    http://www.vexrobotics.com/276-2193.html
  12. 3DprntrMike
    That looks like a handy little ESC, ill have to check the current draw on the motors though, it's only rated to 4A max, and these are awfully "hot" for a 130, my bench supply says each motor draws around 4A at 6V no load
  13. rcengr
    That's more than hot! Could it be that you have 1.5volt motors? I would drop the voltage on your supply and see at what voltage the no load draw drops to a reasonable number. You don't want to end up like my on my first sea trials - I melted a pair of 380 motors, the end bells literally melting and the windings were completely black. That was a pair of 6V motors that drew 10amps each when in the water.
    The 130 motors I run in my PDN draw around 1 amp at full throttle, driving a 1.25" prop on 6.6 volts.
  14. Maxspin
    Maxspin -->> C T D <<--
    Yelm, Washington
    Tugboat likes this.
  15. SteveT44
  16. 3DprntrMike
    I re checked my motors, they draw 0.5A @6v no load and somewhere north of 6A at stall, so any 5-10A ESC will do. i do have a hobbyking Xcar ESC so i will use that until i run out of room in the hull.
    i got some brass tube and built the prop and rudder shaft stuffing tubes. now i just have to find some tiny scale propellers.
  17. irnuke
  18. NickMyers
    Hows this one coming?
  19. pbhawkin
    pbhawkin Member
    Yes, I am interested as well.
  20. Captain obvious
    Captain obvious Active Member
    Hastings, MI
    Very cool. Any updates?
