Cannon Building
Discussion in 'Weapons & Pneumatics' started by tgalx3, Apr 30, 2010.
  1. tgalx3
    tgalx3 Well-Known Member
    Snohomish, WA
    I would like to try to build my own guns. Does anybody have a list of materials for them. fast gun. I have a good idea but I dont want to miss anything.
  2. GregMcFadden
    Do you need cannons now or can you wait a bit? I probably have almost everything needed in a scrap bucket I can bring to the next cle elum battle...
    -Greg
  3. NickMyers
    Is there anything you don't have or can't do Greg?
  4. GregMcFadden
    fancy lathe work, but I make a decent pass at it on the mill.... I may not have pistons/springs but I have a crapload of tube and copper fittings sitting in a box somewhere. I used to make cannons like the BC ones and let me tell you, making them sucks. I really should look into a small lathe sooner or later just to make plastic pistons.
  5. phill
    phill Active Member
    I've built quite a number of cannons for club members. I've got a couple of spares sitting around.
    Required tools: small drill press, Dremil tool. cut off blade, boring bit, torch, solder.
    Helpful: mini cutoff saw, bench grinder
    Hard to find materials: ss rivets $40 per box, springs from small parts,
    Limited source materials: small co2 hose.
    Common materials: copper tube, brass tube, brass fittings
  6. SnipeHunter
    $40 for a box of rivets!!! holy BB Batman
    McMaster-Carr sells boxes of 100 SS rivets for ~$10-$15.
  7. phill
    phill Active Member
    This was years ago and I think the box had 100 in it so I have many years to go till I hit the half way point.
