Cannon parts sources
Discussion in 'Weapons & Pneumatics' started by GregMcFadden, Feb 9, 2007.
  1. GregMcFadden
    For those trying to make piston interrupter cannons, rivets that can be used as an interrupter can be found here
    http://www.mcmaster.com/nav/enter.asp?pagenum=3201
    or search for solid rivet. available in stainless, aluminum , etc.
    also you can search for your appropriate springs there or at
    www.smallparts.com
    As far as tubing, both rigid and flexible (along with the brass fittings) are available from www.mcmaster.com, www.smallparts.com, http://www.onlinemetalsupply.com/
  2. JustinScott
    JustinScott Well-Known Member
    Excellent post! Thanks!
    I'll have to put this in the known vendors section.
  3. specialist
    specialist Active Member
    Note also that #8 2.5" round head stainless steel wood screws with the treads cut off make good pistons. You can order them from small parts also. Also #8 nylon screw insulators make a good spring buffer- the short ones (1/8"?) don't require trimming.
