Bob I made a proposal on the yahoo treaty site to extend thhe front and rear quadrants to 60 degrees rather than the existing 30. this would be for all class 5 and above and all class 4 with 70 foot or greater beams.I nedd to have it seconded by sat to go to a vote arent there a couple guys up your way that have batteled once that could second it thank you
Mikey and I were talking about an extension from 15 to 45 degrees per side rather than 30. What are your thoughts on that? Bob
I put it at 30 because I did not think i could get 45 i would lov e that. I will modify my post then you can second and third
I recommended to Phil that he propose changing it to only 30 degrees off the center-line, as I felt that a proposal changing it to 45 degrees would simply not get enough support to pass, which would be frustrating. Of course, that is just my oppinion. Mikey
