Epoxy thinning?
Discussion in 'General' started by Tugboat, Dec 17, 2012.
    For the guys who are thinning West System, what are you using to thin it?
  2. GregMcFadden
    Why are you thinning it?
    http://www.westsystem.com/ss/thinning-west-system-epoxy/
  3. jadfer
    I never thin mine either. I found that light sanding in between coats can bring a nice smooth shiny surface.
  4. SnipeHunter
    I've done it with either acetone or paint thinner, don't remember which one.
  5. mike5334
    Usually I do not thin West Systems ... it was made thin. :)
    But, I have thinned epoxy with alcohol (none denatured/no water added kind) and acetone. Both work well.
    I don't generally thin it. But I have been known to make sure that it is warm. That seems to make it act thinner.
    Unless you are wanting it sorta thick.
    I was going to thin it to soak the new Scharnie decks. From reading West's pdf, it seems that they regard this as unneccessary.
  8. tgdavies
    tgdavies Active Member
    To quote from the document at the link Greg gave: "an epoxy coating on the surface is more water-resistant than a thinned epoxy coating that has penetrated deeply into the wood because, in most instances, the epoxy thinned with solvent is porous."
    Indeed, I thought I quoted it pretty accurately:
    :):D:):D:):D:):D:):D:)
  10. Renodemona
    During winter I use a torch to warm it up quite a bit after mixing, it thins it out a little. Also, it makes the neighbors think I'm crazy (or re-affirms that view as the case may be). I'd just mix, pour a thin coat over the deck and even it out with a really cheap brush, sand with 600+ grit and do a VERY light second coat. Comes out really shiny. I don't put 2 coats on...but I don't really go for pretty.
