Can you guys walk me through the setup of a fast gun triple? Accumulator? Multiple accumulators? Multiple valves? Tube diameter? How do you balance it so all three o-rings fire at the same time?
For my Des Moines which has triples. I have 3 accumulation tanks one for each gun and then I have a single gun board that fire all the cannons on one pull of the trigger. I am running the smaller 1/4” tube from reg to the accumulation tanks and then from tanks to solenoids and then solenoids to guns
You can also add a check valve on the supply going to each tank. Need to be able to test guns individually with either test switches or unplugging. Here’s my preferred setup, with clippard 1/8npt in line check valves and aluminum tanks Guns need to tweaked consistently, can’t have one gun hang up a bit
