This case is really cool. I designed and had it cut the way it is. It can use power from AC and DC. The purpose of this is so you have the freedom of charging up to 4 batteries during a battle and while you’re patching up your ship. Then at that point batteries are done charging while in that repair time. 2amp is the preferred charging rate. It now has lights for the captain that wants to battle at night. It has an extra xt60 plug to give power to whatever you want to power up. It has a usb c and usb a plug in to charge said 2 phones or possibly 2 go pros. I’m hoping to make a small profit to recoup some of my over all ship cost. While giving captains the chance to benefit from a very convenient charging case while at the lake or pond side. P.S. I will have the box powered on when I have the final touches on the lights.
Whats the price? what are the specs on the chargers? 50 watt? 100 watt? Does the box need to be plugged into a 110 outlet? Does it have cables to connect to my car battery? does it have settings for Life batts or is it lipo only? Can i charge my Nimh cells for my convoys? Enquiring minds wanna know.
Thank you for asking all these questions. I would love to answer all these questions. In the order you mention them. 1 Price= I haven’t set a fixed price yet because I haven’t priced out every item yet because I’m still in development. I want to make it as low as possible yet make a small gain to recover from building my ship. I will give this information as to some cost. The case alone was $185.00, not including any parts or labor. 2 Charger Specs= IDST Q6 Retro 350W 16A DC Lipo Battery Balance Charger/ Discharger. It too is 50.00 Specification: Charging power: DC 350W Charging current: 0.1A-16.0A Discharging power: 10W Discharging current: 0.1A-1.0A Input voltage: DC 10-30V Output voltage: DC 1-30V Supported batteries: LiFe, Lion, LiPo 1-6S LiHV:1-6S Size: 80*80* 33.5mm Weight: 119g If you let me know what your charger is I might be able to customize the deck and box for your need. 3…..
3-4 & 7 answered through #2 5 DC/ AC Power= It has two ports for the need of drawing power. One port (AC)is 3d printer plug in for ac wall power or outside extension cords. 110 ac when it is available or at home. 6 (DC) Second port is an XT90 next to ac plug in. The port is for car batteries or bigger lipo batteries for people that are more confident. Yes, it can use alligator clips to connect to a battery. The cord is NOT INCLUDED. I’m hoping people can be creative enough to make one. (Going from station to battery) BUT for an extra cost, I can make them. 8 &9 No. According to the charger specs. There are ISDT Chargers that can but the one I have won’t. I don’t really work with Nim. 9 That being said, the case does have an extra XT60 POWER output. I use mine for a HPA compressor. You can use it for powering another charger.
