Firing Board Failure - help please
Discussion in 'Weapons & Pneumatics' started by tgalx3, Apr 26, 2023.
  1. tgalx3
    tgalx3 Admiral (Supporter)
    Snohomish, WA
    I have installed polulu firing boards in my boat. The board that is controlling the stern gun has failed catastrophically twice now (sparks and small flames). The board that controls the bow gun works perfectly. Solenoid triggers as fast as I press the stick. Both boards are wired up the same.
    The only difference between the two boards is that the bow gun, which works properly, has a signal inverter on it and the stern gun does not.
    Side note, I have not cut any of the wires from the receiver and am using power from the main batteries to run the entire system. Not sure if that helps at all.
  2. Beaver
    Picture of underside and connectors?
    Did it catch fire when plugged in or when activated?
  3. Kotori87
    Is there a flyback diode, and is it installed correctly?
  4. tgalx3
    Snohomish, WA
    It caught fire only when triggered.
  5. tgalx3
    Snohomish, WA
    There is a flyback diode its at the solenoid. Its soldered on, I feel pretty confident that its in there correctly. But haven't tested with with a multi-meter.
  6. tgalx3
    Snohomish, WA
  7. tgalx3
    Snohomish, WA
    Uhhhhh. I did just notice (after looking at my own picture) that the silver band on the flashback diode is on the black side. The silver band is on the red side on the board that is working properly. Im not an electrical engineer, is that something that should be swapped....?
    notSoGnarly likes this.
  8. Beaver
    Silver band should be on the positive side. That is likely your issue.
  9. Kotori87
    Yes. If the flyback diode is connected wrong, it will short-circuit whenever you try to trigger the solenoid. That draws too much current and damages the control board. I made that mistake once, and I got to watch electrical bits glow orange and combust.
  10. tgalx3
    Snohomish, WA
    Hey!!! Me too. Fireworks in April. I’ll swap it around. Thanks guys
  11. tgalx3
    Snohomish, WA
    It works!!
    notSoGnarly and Xanthar like this.
  12. GregMcFadden
    Uhhh... If you are using the medium MOSFET pololu switch there is already a diode on board for use with highly inductive loads, and another is not required.
