I have a brand new FlySky Fs-i10 i need to sell. I purchased this for the North Carolina Build i was planning, but if you've seen that post you know i'm selling it as i'll be moving & hopefully buying a house here in the next few months. So since i'm selling the boat this radio was going to be for it needs to go as well. Here is a link to the radio on amazon if anyone wants to look at it View: https://www.amazon.com/Flysky-Transmitter-FS-iA10-Receiver-Quadcopters/dp/B00I19QI0I Details are also listed below. Specifications: Channels: 10 Channels Model Type: Glider/Helicopter/Airplane/Quadcopter/Drone RF Range: 2.4000-2.485GHz Bandwidth: 500kHz Band: 160 RF Power: Less Than 20dBm 2.4ghz System: AFHDS Code Type: GFSK Sensitivity: 1024 Low Voltage Warning: 3.7V DSC Port: PS2 Output:Micro-USB PPM Charger Port: No Antenna length:26mm*2(dual antenna) Weight: 720 g Input Power: 3.7V 1700 mAh Display: WQGA 3.55-inch TFT color screen 262K 240 * 400 dot matrix LCD white backlit resistive touchscreen Dimensions: 190 * 95 * 255mm Online Update:yes Exterior Color: Silver Certification: CE0678, FCC Package including: - 1 x FS-i10 2.4G 10ch transmitter - 1 x Battery - 1 x FS-APD01 (magnetic speed sensor) - 1 x FS-APD02 (optical speed sensor) - 1 x FS-AVT01 (Votage transducer) - 1 x FS-ATM01(temperature transducer) - 1 x FS-IA10B (reciever) - 1 x User Manuel I would like to get at least 150$ for this. This price will also include shipping to your door as long as you are in the US. Please reach out if there is any interest. Thanks guys!
