Foam?
Discussion in 'General' started by gunner250, Sep 2, 2013.
  1. gunner250
    gunner250 Active Member
    Missouri
    Why do you use foam in the ships.
  2. KeriMorgret
    Seattle, Washington
    A lot of time a dense foam is used for the superstructure pieces. It's lightweight (because on the smaller ships weight can really be an issue), can be painted, and resists BBs.
  3. gunner250
    Missouri
    well look at some post on build the Missouri and it seem they where using foam as armor or somthing
  4. absolutek
    You're going to need to be more specific, in fact, I would suggest you even ask on the missouri thread about it.
  5. gunner250
    Missouri
    they were using it as inner armor from the looks of it.
  6. absolutek
  7. Anachronus
    Water channeling maybe?
  8. NickMyers
    He is probably referring to Stokamoto's NC build
    He uses foam mat in two places here, first on the bottom of the hull to build up the waterchannel, and second, he used the not very useful otherwise interlocking edge scraps to hold his internal armor in place. I can't say I've ever seen internal armor held in that way, but it looks like it works well and uses scrap material that otherwise wouldn't get used.
    (You cant see much of where he used it in the waterchannel here, but from OP's comments I figured he was more interested in the pieces holding the shielding in place)
  9. gunner250
    Missouri
    http://rcnavalcombat.com/Forum/tabid/58/aff/566/aft/441989/afv/topic/Default.aspx
  10. gunner250
    Missouri
    never mind i thought i read it somewhere on there
