Fun with coiled mags
Discussion in 'Weapons & Pneumatics' started by SteveT44, Aug 24, 2017.
  1. SteveT44
    dietzer and Kevin P. like this.
  2. Beaver
    Is that the stuff you were playing with before or something new? Looks good though.
  3. SteveT44
    Same stuff.
  4. Anvil_x
    I've been wondering if anybody had come up with an alternative magazine concept, especially since my haymaker's mag has gone and crapped out on me.
    Lo and behold, it did happen. what's the parts list on this mag setup? are you using a barbed attachment and 1/4 tubing and a PTA on the end?
  5. Xanthar
    Xanthar Well-Known Member
    Upstate NY
    Does the plastic fitting require much "Machining" to hold the o-ring?
  6. NASAAN101
    is that a plasic Mag?
  7. Anvil_x
    yeppers.
    it's the same sort of hard tubing that we use for the main CO2 lines, but instead of 1/8", it's 1/4" which has an inside diameter the same as our standard copper mag tubes (0.19)
  8. NASAAN101
    I'm getting 100 feet of house :D when i get the gun stuff :D
  9. Anvil_x
    that's the next item on my grocery list. Steve posted a link on my build page for the 1/4" hose if you need it
  10. NASAAN101
    can you use the bigger house on the guns instand of both?
  11. SteveT44
    FYI, the coiled tubing doesn't feed bb's out of the box. It needs to be prepped for that. This involved squeezing the tubing along it's length in a flat faced vice to open it up. Since nylon tends to go back to it's original shape, I wasn't expecting this to hold but it did feed bb's a few days after the process. I haven't checked since but I'll pull it out of the box tonight and see if it's still feeding bb's.
  12. Anvil_x
    cool, good to know
  13. SteveT44
    Pulled the coiled plastic mag out of storage over the weekend. Still feeding bb's just fine.
