General Rules and Guidelines
Discussion in 'General' started by hidrodynamic, Jan 26, 2008.
  1. hidrodynamic
    hidrodynamic New Member
    I lurked around the forums but couldn't find any set of rules or build guidelines. I'd just like to know what specs I can build a ship to, whether it has to be modeled after a real ship or a design that I come up with can be used.
    Any links to rules would be helpful.
  2. warspite
    warspite Active Member
    ☘️ The Irish Sea ☘️
    Different rulesets have different construction rules. I battle under the Model Warship Combat rules (www.mwci.org). Under MWCI you can only use ships that were _launched_ between 1905 and 1946 (i.e. ships that actualy hit the water). I believe the Washington Treaty rules and Big Gun allow you to use ships that were laid down but perhaps never completed (which allows you to use ships that construction was started on but were never completed for one reason or another). I am not aware of any rules that allow you to design your own ship.
    Some helpful links would include:
    www.mwci.org - Model Warship Combat Inc
    www.ircwcc.org - International R/C Warship Combat Club, Inc
    www.rcwarships.com/rcwarships/homeports.html - Big Gun Portal
    http://groups.yahoo.com/group/TreatyCombat/ - Washington Treaty Rules
    Hope these help
  3. GregMcFadden
    where are you located? we can help you find a local club if one exists
  4. Anachronus
    Hidro, Warspite where in louisinana are you two located.
    James in Baton Rogue
  5. warspite
    ☘️ The Irish Sea ☘️
    I am in Monroe...
  6. Anachronus
    Excellent. Only 3.5 hours away. When I get my cruiser done that is a convenient distance. Lack of opponents has been what has slowed down my construction times.
    James
  7. warspite
    ☘️ The Irish Sea ☘️
    James,
    I would be happy to have My Scharny chase your cruiser around. Wade Koehn is actualy in New Orleans and he is a vetran battler with a number of ships. He is actualy working on getting a pond together. There is also a large group of folks in Houston that get together as well.
    As far as lack of opponents do not let that slow you down. Unless you live in Florida, battling will generaly require a roadtrip. There will hopefuly be a battle in Houston in the spring, and they have battles planned in Orlando in Feb and March, and Savannah in April. I am hoping there is enough interest in putting together a June battle in Atlanta as well.
    Good luck with your ship,
  8. Anachronus
    Sounds fun, even if it does make the Axis look like a bunch of back stabbing fiends... :)
