Graf Spee Motors
Discussion in 'Propulsion' started by tgalx3, Jun 20, 2022.
  1. tgalx3
    tgalx3 Admiral (Supporter)
    Snohomish, WA
    I’ve never built a ship this small what kind/size of motors are recommended for the drive and ideally the pump?
  2. Boatmeister
    Boatmeister Active Member
    Chesterton, Indiana
    550's are are the best all around motors, but twin 380's would work if you're battling big gun. Depends on your internal layout
  3. tgalx3
    Snohomish, WA
    Yea I'm building 1/144. So I would do two 550s then.
    On my old Bismarck I had a single giant motor(don't remember the size) so I would do 3 smaller motors instead? Also, am I correct in understanding that the rules say the Bismarck would need a drag disk?
  4. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
    It depends on the rule set. Fast gun, you would just need to have a dummy prop or drag disk for each unpowered shaft.
  5. Bob
    What size props are you using. For 1.25” a 390 motor works well direct drive. For 1.5” and larger a geared system with 550 works well. Or there are also lots of brushless choices.
    On my Graf Spee I used 550 and a gear box.
  6. tgalx3
    Snohomish, WA
    Im not opposed to gear boxes. I do like direct drives better.
  7. Bob
    Gear boxes make a huge difference in your acceleration and deceleration. Once you get into a ship that’s more that 10lbs you really should use them.
  8. tgalx3
    Snohomish, WA
    How do gear boxes help acceleration and deceleration?
  9. Commodore
    Commodore Well-Known Member
    Sunny TX
    Think of it like your car. Imagine if you didn't have 1st, 2nd or 3rd gear, but only 4th +. Accelerating from a stop would be kind of hard, right?
    Electric motors are happiest at higher RPMs. Props are happiest at lower RPMs. Gearboxes give you the best efficiency, and low end torque for when the light turns green.
