Hello Again.
Discussion in 'General' started by nativecaptain, May 20, 2015.
  1. nativecaptain
    nativecaptain Member
    Hello Captains
    First off i like to say, i like the look of the new site. I know it been a few months since it change, but i've been really busy with school. hope everyone enjoying the great weather.
    Unfortunately it look like i will not be building this summer, dealing with school and renovation. I do hope to get Libby in reliable working condition, last year ended with her hull get wet. Good new no leaks, bad new steering keeps getting stuck and drive shaft keeps slipping loose.
    I also would like Libby to be a transport ship by the end of the year instead of an aircraft carrier.
  2. NickMyers
    Hi there, welcome back! I'm glad you like the new site, some items are still works in progress but I like to think we're reached a state of all-around improvement.
    I went back and looked at pictures of your Lib. Are you getting stuck with the rudder hard over? You can only go so far with a pushrod system before it locks over, place with reducing the throw (or switch to gears or chains)
    Drive shaft loose, how are you coupling it to the motor?
  3. nativecaptain
    This is how its set up I forget the name for this set up. the problem is that the screws keep slipping on the shafts. I made a flat area with a file before assembling.
  4. NickMyers
    Setscrew.
    Thats a rough angle there.
    Apply some loctite to the threads and screw the setscrew down. Let it sit a bit to do its thing before use
  5. nativecaptain
    Ill have to try it with crazy glue and hope it works.
  6. irnuke
    Problem is with the angle your dogbone is at. The greater the angle, them more vibration as the dogbone rotates past the collar notches where the pins insert. This vibration shakes the setscrews loose.
    Recommendations: if possible, remount motor so it's better aligned with prop shaft. If that's not possible, you could try moving the motor further back & using a longer dogbone (longer = less angle = less vibration)
  7. Cannonman
    Hermitage, Tn
    I'm kind of shocked it's not throwing dogbones with that angle, this has got to be close or maybe even beyond the maximum they can even function with. If the shaft of the dogbone touches the coupler anywhere, you are beyond the true mechanical limits of what will even work. irnuke gave the best two solutions to your issue. Even if you can keep the setscrews tight in the current configuration, it seems like the dogbone itself will likely fail at a very inopportune time in battle. ;)
  8. nativecaptain
    Thanks for mentioning the angle problem, i really never thought of that. So i took mount out and sanding down the bottom and adjusted the screw holes to allow better adjusting.
    Here is the adjusted mounting, unfortunately I lost the screw for the coupling.
  9. Cannonman
    Hermitage, Tn
    That looks much better! Glad it was a relatively easy fix, hopefully the screws will stay tight now. Either way your dogbones will be much happier!!
  10. Cannonman
    Hermitage, Tn
    Have you had a chance to look at the rudder setup yet?? If you get stumped post a picture or two and someone will have some good advice on it. :)
  11. nativecaptain
    I got a chance to take Libby out for a little swim. The rudder assemble works, I'm guessing i worked on it last year. She ran well for 20 mins before the stuffing tube seized, i'll have to look into it later, since I have midterm and paper due the next week. I also realized how much weight needs to be added.
  12. Cannonman
    Hermitage, Tn
    Did you lubricate your stuffing tube??
  13. nativecaptain
    Hope this answers your question
  14. jch72
    jch72 Active Member
    Are those 2100KV motors? On direct drive? What voltage are you running?
  15. Beaver
  16. jch72
    jch72 Active Member
    That is what I was thinking. Those will be some good pump motors some day, it is like the one I have on mine that has lasted 3 Nats so far, but a little smaller I think. Maybe the high rpm is contributing to the seized shaft and the set screws vibrating loose. I wonder if the ESC can handle running on a single cell? For a frame of reference convoy ships are about half walking speed.
    I remember building in college, hydroplaning across the pond in my first ship, the Prinz Eugen, powered by 3 380 motors.
  17. nativecaptain
    Yes believe there is too much motor for the ship, I never went full throttle it sounded to scary. As far as changing the motor out, i dont see it happening in the near future.
  18. Cannonman
    Hermitage, Tn
    You should be able to dial it back with the endstops on the radio, if yours has that option. Then swap it out for a more suitable one when you can.
  19. McSpuds
    McSpuds Vendor
    Louisville, Ky
    LOL the end point will be set on 1%... and then you will still need 2in diameter drag props...
