Hello
Discussion in 'Introductions' started by Aggie9255, Jul 23, 2012.
  1. Aggie9255
    Aggie9255 New Member
    My name is Malcolm, im from North Carolina. I have been looking around the site for a while and now im getting ready to build my first ship. I was thinking of doing a
    Sumner/Gearing class ship. Since some have said it was on the easier said. I
    was wondering if anyone knew where I could get the plans, or frames and subdecks for it.
  2. bear23462
    bear23462 Active Member
    Welcome aboard Malcolm. What group are you planning on battling with? You may want to hold off on making a decision on which ship you would like to build until you know what ruleset you will be using.
    Ken
  3. Aggie9255
    Well I want to build one for the experince so I can improve upon it once I am decided.
  4. bear23462
    Well Malcolm, in a Big Gun format such as we use here in my area of VIrginia a Gearing Class Destroyer would be around 32 1/2 inches long and a little less than 3 1/2 inches wide at the beam. Not a lot to work with in my format.
  5. Aggie9255
    Thats fine i want to start smaller means if i can get stuff right, it should be easier once i move on to something bigger.
  6. NickMyers
    No. Its easier to get stuff right in a larger ship like a battlecruiser. Destroyers are small, difficult, frustrating and expensive.
  7. Aggie9255
    WELL...any suggestions? I would rather have it easier, and where to get plans cause only place i saw was strikemodel. and Hello Nick and Ken.
  8. bear23462
    Well there is a Ron Hunt from Greensboro, NC with the Tarheel Attack Group. He is on this forum and you may want to contact him. For a Fast Gun ship I would recommend something like a Des Moines class heavy cruiser ship is almost 60 inches long and has a beam of 6 1/3 inches good space to work with and not a lot of armament.
  9. Aggie9255
    60 inches....dang
  10. bear23462
    I am currently about to finish building an Iowa class battleship hull. It is 74 inches long. You should check out the build thread Wisconsin Build Diary.
  11. jch72
    jch72 Active Member
    The nearest battler to you that I know of is Rob Stalnaker who lives near Concord. He just got through hosting two Nats back to back. We do both ircwcc and mwci format. As far as a ship if you really want to stay small and light and american I would recommend a light cruiser like the Atlanta, the gearing is really fast and tippy which means you will probably sink a lot with very little or no damage. A Light cruiser would have a second gun and can be a lot more effective than a destroyer if you aim both of them at the same spot aft. Typically small cruisers and destroyers accelerate well, but have a wide turn radius compared to battleships and battlecruisers.
    Ron Hunt
