HMS Prince of Wales 1/96
Discussion in 'Warship Builds' started by glaizilla, Oct 3, 2013.
  1. glaizilla
    glaizilla Active Member
    This will be my build thread for the other half of the Limy portion of the Denmark Straits combatants. Today I extrapolated the quantity of ribs for 3/8" wide on the strike face. I had wanted to pose a question in regards to armament, that by the time the ships frame was begun, I would have a game plan laid out.
    Option a
    arm all three turrets with dual 7/32" Cannons and atempt to fire A and Y turret at twice the normal rate to simulate quads of proper caliber
    option b
    arm all three turrets with 1/4" quads (b turret with outer two barrels plugged), and atempt to fire the 7/32" ammo.
    option c
    build 8x 7/32" arizona style guns, fix a turret to one side of ship, with y fixed opposite, and a rotating twin 7/32" in b turret.
    the first two choices I had thought of utilizing the same diameter magazine guns, to try and ease the task of synchranizing a turret with b turret.
    any thoughts?
    I like B. Wouldn't it be easy enough to buy the right size of tubing to fit a 7/32" I.D. barrel to a 1/4" gun (i.e. sleeve it to fit at the breech)?
  3. glaizilla
    I think it would be somewhat possible. I know Mikey and Dustin have tried to get a set of quads in the Strasbourg to fire the 7/32. The ones in the ship now seem to be fairing better than the other sets of 1/4" quads. I haven't attempted to sleeve the risers out of the magazines but perhaps with some help it could be done.
  4. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    Sleeving the risers does work. Seen it. Done it. I highly recommend right sized barrels as well. If worse comes to worse. Buy some cerrobend and bend your own.
  5. glaizilla
    The ribs have been cut out for the POW, I am using the inner radius wast of the ribs as stock for a 1/144 Sovetskii soyuz project, the Subdeck has been cut out. I have another project that is being built along side the POW in Battlestations, alls I can say is the British are rolling in heavy next year....
  6. buttsakauf
    Garland, TX
    You have good hull lines for a Sovetski Soyuz?! I have yet to be able to find them. Can you point me in the right direction?
  7. Kotori87
    In 1/96 scale, you might have enough room to rotate a four-barrel MJV cannon. That is a possibility worth investigating. Regardless, I would suggest you consider option D: arm A turret and C turret with quads, and leave the B turret as a dummy. The dummy turret can be used as a recovery float, carry a camera, or just be a decoration. But the added firepower of one twin turret is insignificant next to two good quads, and you'd get a simpler and more reliable ship with only the quads.
  8. Kun2112
    Option A wouldn't allow enough time for the accumulator to refill. I say B or Kotori's suggestion.
