How do you paint a waterline stripe?
Discussion in 'General' started by Julian Barbera, Sep 8, 2019.
  1. Julian Barbera
    Julian Barbera Active Member
    SF Bay
    Hello all. I'm looking to paint my newly sheeted VU, but am unsure on how to paint my waterline stripe. Do you use math, or throw your boat in the water loaded and draw a line? Much appreciated!
  2. SnipeHunter
    Do all the math you want but what matters is the actual waterline when you put it in the water, so just do that.
  3. Julian Barbera
    SF Bay
    Thanks!
  4. Commodore
    Commodore Well-Known Member
    Sunny TX
  5. Kevin P.
  6. Bob Pottle
    Nearly everyone in NABS (20+ members when the club was active) used auto tape for waterlines. I don't think it had any significant effect on penetrability - we did a lot of penetration tests on it at competitions and there were no failures unless the underlying balsa was too hard. A memorable example was a hull painted with epoxy paint.
  7. Commodore
    Sunny TX
    In the past, I have seen people get the K-mart quality tape and have problems with it. The 3M stuff, on the other hand is wonderful goodness.
  8. Z Boat
    Z Boat Well-Known Member
    Roseville California
    I paint on waterlines wider than 1/4" and I found if you spray clear over the tape then paint the water line it will have very few bleeds using the cheap tape..
