How would you be able to build a 1/4 bb gun
Discussion in 'Weapons & Pneumatics' started by JKN, Jan 17, 2010.
  1. JKN
    JKN Member
    How would you be able to build a 1/4 bb gun?
    I was able to figure out how to build one for torps but not 1/4 bearings
  2. Kotori87
    JKN, how to build a 1/4" bb cannon depends on what sort of cannon you want. There are:
    MJV single-shot cannons
    MJV reloading cannons
    MJV rotating cannons
    Indiana-style non-rotating cannons
    Indiana-style rotating cannons
    Indiana-style piston breech cannons
    Indiana-style sliding-breech cannons
    Canister-style cannons
    Canister-style piston breech cannons
    Canister-style sliding-breech cannons
    canister-style negative-pressure cannons
    Stomper cannons (canister-style sliding-magazine)
    Trombone guns
    O-ring guns
    jam-elbow guns
    AK47 torpedo cannons
    HE (high-efficiency) torpedo cannons
    Grease guns
    PVC accumulators
    copper accumulators
    aluminum accumulators
    MAT tank accumulators
    o-ring seals
    shoe-goo seals
    superglue seals
    solder seals
    threadlock seals
    PVC valves
    MJV valves
    ABS valves
    brass valves
    aluminum valves
    PVC magazines
    lexan magazines
    aluminum magazines
    sewer pipe magazines
    wooden magazines
    single guns
    double guns
    triple guns
    quadruple guns
    hextuple (six-barrel) guns
    low-profile guns
    compact guns
    depressing guns
    submarine guns
    top-loading guns
    compressed air guns
    CO2 guns
    railguns
    wave motion guns
    the list goes on and on... Your choices affect everything from operating principles to manufacturing techniques to ease of maintenance, and everything in between. The simplest cannon is an MJV cannon. You put a MAT-2 accumulator on a MJV-2 valve, with an MPA-3 actuator to fire it. Install a 1/8NPT to compression ring fitting, then stuff in a 3/8" brake line barrel and tighten everything down. Materials cost about $25. Adding reloading is easy: replace the 1/8NPT to compression ring fitting with a 1/8NPT to compression ring T fitting, and modify it to use a sliding piston breech. Material cost about $26 plus a little drill press + lathe work. More complex than that? buy the weapons manual from Strike Models, and build the cannon detailed in those plans. Or wait until Strike Models starts producing their own Big Gun cannons, which I hope will be early this year.
  3. Anachronus
    Strike has the weapons manual? Excellent!
  4. GregMcFadden
    I would add that as far as engineering plastics go, I really like noryl EN265 (I believe the chemical is Polyphenylene Oxide) for instances where I would normally use delrin/acetal but want to be able to use an adhesive on it... and have it stick.
  5. Anachronus
    Kotori,
    I just caught the last one on you list.
    Have you seen the trailer for the live action Yamato movie?
  6. Kotori87
    Just saw it. Oh boy, I can't wait!
  7. Anachronus
    Looks like a very faithful adaptation. The website goes live in about 16 hours.
    http://www.yamato-movie.net/
