Introducing USS Chester
Discussion in 'Digital Design and Fabrication' started by Beaver, Dec 30, 2022.
  1. Beaver
    Introducing USS Chester - A freely available 1.5unit cruiser for novices and experienced captains alike!
    I've been working on designing a 3d printable hull and it hit me half way through that Chester would be a fun ship to make available to the community. She should be a relatively easy build. At 6lbs displacement she still has an inch of freeboard available and the hull is roomy enough for a single cannon or two half unit guns.
    I plan to offer 3 different sets of files eventually, STL files to print your own, DXF files for a CNC routered or lasercut wood hull, and templates to cut your own hull out of wood.
    Hopefully there is some interest in this project as I'd love to see some of these on the water!
    Feel free to drop any comments or questions below!
  2. Commodore
    Commodore Well-Known Member
    Sunny TX
    I'm really surprised you didn't pick Tennessee (armored cruiser) or Blucher (whinny) ...
    glaizilla likes this.
  3. Beaver
    I made this because I wanted it and decided not to be selfish and share. Blucher and Tennessee are cool but I'm not itching to build one.
    Panzer likes this.
  4. Radioman
    Radioman Active Member
    Franklin Wisconsin
    COOL!!!!!!!!!!!!!!!!! I want one. When will the files be ready?
  5. Beaver
    I'm still working on fleshing out the 3dp version. Hoping to have it ready in the next few weeks.
    Lord Haw Haw and Panzer like this.
  6. Commodore
    Sunny TX
    Ah, and here I thought armored cruisers with sidemounts were going to be this year's new hotness. Go figure.
    All the same, it's very cute, and thanks for being generous and sharing with everyone. I tried to do that once and someone went and ignored the Von der Tann superstructure that I posted. Along with a few others, apparently.
    (sigh)
  7. Beaver
    Been working on the internal arrangement. Trying to plan everything out so it can be assembled and everything has a place. The overall idea will be purchase everything on X part list and install in a matter of hours. I plan to supply instructions so even a new person can figure it out.
    webwookie, Mark41, glaizilla and 4 others like this.
  8. Beaver
    Ok! I think it's ready for the prototype to be printed! I just have to add the connecting tabs to the pieces but otherwise it's ready to go. I had @bsgkid117 look over the model and give his blessing (thanks) and then split it into 4 sections. The longest is 255mm so this should fit on most medium to large format printers.
    glaizilla, bsgkid117 and Lord Haw Haw like this.
  9. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
    I don’t see any alignment dowels or pins?
  10. Beaver
    That's what needs added before the first hull is printed. Working on it. ;)
  11. Commodore
    Sunny TX
    Extra kawaii!
    For simplicity, have you considered a version with a single 50 round stern gun?
    Lord Haw Haw likes this.
  12. Beaver
    The "base" version will be a single 50rnd gun. That would be the recommended beginner setup. If you wanted more guns in the future then you can split the unit for a bow gun or whatever you want to do. That much is left to the captain.
  13. bsgkid117
    You've done a great job. As I said in our little chat while I looked over it, I couldn't have done it any better myself. Most of my suggestions were just from my experience with the transition of digital to physical.
    Looking forward to seeing a finished product. May print one or two myself just for laughs, I think I can print a whole one in 1 print :laugh:
  14. SteveT44
    Which solenoid is that in the model?
  15. Beaver
    It's a Spartan.
    Panzer likes this.
  16. Nomercy
    Nomercy Well-Known Member
    Maryland
    Welcome back Steve. Good to hear from ya.
    Evan Fowler likes this.
  17. Beaver
    Had a few minutes to work on this tonight. The bow section has captured nuts now.
    Evan Fowler, Nomercy and SteveT44 like this.
  18. Beaver
    Work continues on adding the bosses to bolt the hull together. Unfortunately on this small ship there isn't quite enough room to fit the bosses on the inside around amidships so to get around that I'm going to try bolting the hull together from the outside. The bolt is angled 10° to allow access for tightening. Fingers crossed this works!
    Panzer likes this.
  19. SteveT44
    I take it since your using connecting screws, that glue isn't strong enough to hold these printed hulls together?
  20. darkapollo
    Carlisle PA
    It is.
    With ABS I use acetone to melt the mating surfaces and clamp them together. This chemically fuses the sections making them actually stronger than the layers alone.
    The bolts are there to provide a clamping surface while the glue or acetone cures. On my Baby Jersey, I no longer have the bolts in the ribs and the hull is plenty strong.
