IX-300 Build (Prinz Eugen)
Discussion in 'Warship Builds' started by notSoGnarly, Aug 9, 2023.
  1. notSoGnarly
    notSoGnarly Well-Known Member
    Starting a thread for my PE hull build.
    1:144
    IRCWCC Fastgun
    Admiral Hipper Class
    3.5 Units
    23 secs/100ft
    I'm going to name it "IX-300"
    It's one in a series of boats that will be my first from scratch builds. I am starting a few together and doing work in stages.
    Got the hull from a fellow captain. It came uncut with decks, 3D SS, drive shaft w/prop, and stuffing tube installed.
    FritzVanDelen likes this.
  2. notSoGnarly
    Taped up in theory for weight float tests this weekend.
    Pink is 1/8" stringer.
    Black is 1/4" WL.
    Hash up is 1" below center of WL.
    Hash down is 1"below the bottom of WL.
    Red marks are my 45° line.
    (Yes, in the hull length shot the lines get crooked and to low in the stern. I fixed it)
  3. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
    I like it! Following.
    notSoGnarly likes this.
  4. notSoGnarly
    Word on the street is that a single prop 23s boat is going to have some torque rocking.
    I'm thinking about just adding bilge keels while it's early and easiest.
    Thoughts?
    Boatmeister likes this.
  5. darkapollo
    Carlisle PA
    I saw a build a few years ago where the builder used rubber weather stripping tabbed into the hull as bilge keels.
    They are always a good thing for stability.
  6. Beaver
    Lead bilge keels. Did wonders on my Suffren.
    Boatmeister and notSoGnarly like this.
  7. notSoGnarly
    I added them to a Baden hull I had using the 2 strips of basswood and fiberglass cloth. That was pretty easy. I'll probably stick with that method.
    It's a cruiser so it was never going to turn amazing anyway. I'm leaning towards adding them. Coming up with a way to make them removable seems like to much work.
  8. notSoGnarly
    I'm probably going to keep it light on the build and added weights in the hull, then rely on lead strips on the outside. Guess I could try and make lead keels instead. Hmm
  9. notSoGnarly
    Yes I'm replying to myself. We have the best ideas.
    I already have some of those lead duck weight bars. They are 1/8" thick and 5/8" wide.
    I should be able to cut em in half, attach 2 or 3 together, glue it on, add some FG and sand down.
    That should be some nice hefty bilge keels
  10. Beaver
    Get a 2x4, cut 1/4x3/8 deep groove in said 2x4, plug the ends with wood blocks at the length you want the keels. Melt lead and poor into groove till full and let cool. Pop out and glue to hull.
    Be sure you don't use a damp 2x4.
    notSoGnarly and bsgkid117 like this.
  11. bsgkid117
    I did basically what caleb suggested for the lead bilge keels on OG bart. I just happened to have a router with a 3/8 bit, so I just cut a 3/8 deep by 3/8 wide straight groove in a piece of wood that was the right length and voila.
  12. notSoGnarly
    A lil molten lead does sound like fun.
    Just need to go to the thrift store for a pot or something to dedicate to lead work.
  13. Kotori87
    Seconded.. wait, thirded... wait... yeah, bilge keels are very important on tippy boats. They won't prevent the torque-rolls, nor will they help with too much weight up high. But they will rapidly arrest any oscillations. Your boat will just lean over a bit, instead of rolling around like a flower class corvette in the north atlantic. I highly recommend maxing out your bilge keels, and yeah lead is the best material to use for it. Work outside and stand upwind, or get yourself some really good breathing protection.
  14. notSoGnarly
    Did y'all just glue it on and paint it or did you give it some sort of other coating?
  15. Kotori87
    I fiberglassed over my bilge keels. They've been shot a few times so I'm glad I did it.
  16. bsgkid117
    For lead keels on Bart, lots of e6000 and I also drilled into the lead and the hull in 4 spots along the keels length and screwed it in too.
  17. notSoGnarly
    Float test went well. Going for around 15.33 lbs
    Hull is now taped up for ribs.
    1" hard area in the stern.
    1.5" hard area in the bow.
    24 ribs. 23 @ 1/4" and 1 @ 5/16.
  18. Nomercy
    Nomercy Well-Known Member
    Maryland
    YES
  19. Boatmeister
    Boatmeister Active Member
    Chesterton, Indiana
    They say it's ok to talk to yourself, it's even ok to answer yourself, but if you go "huh?" Then you have problems!!
  20. notSoGnarly
    Got all the window holes drilled out and window cutting has started.
    FritzVanDelen and darkapollo like this.
