Hello, I was wondering, could the K class hulls from BC be used to make the light cruiser Leipzig or Nurnberg? Or would you have to lengthen the hull by 3/4" or so? Cheers, Garrett
I don't have prints of any of them. From what I have been told they are pretty close to the same hull shape. You do have to change the hull a little. It's doable without a ton of work.
Can I have a show of hands of those who saw the thread title and was thinking steam powered submarines? Probably just me.
I'd rather do USS Argonaut, 29" long and just under 3" wide. One that I have good plans for and a wood hull sitting in the shop. (Though that could be said for a lot of boats in my case) If I can work out some of my driveline issues with the little tiny brushless motors I bought (1.5mm shaft), it would save a butt-ton of weight and space. Actually, using those motors in a sub would be less problematic than in a DD; I found gears for the motors, but the pinions are plastic and I'd worry about them holding up in a ship that reverses a lot and at a higher speed. A sub is slower and less stressing on the driveline than a DD, I'd think. Once the 3D printer is done, I can print a small gearbox that uses pressed-in bushings for bearings.
