Hi guys I have a guy in ark. that would like to have hulls of the USS Mount Shasta AE ship and or the USS Tangiers , was a large sea plane tender. I have been looking high and low to help him but have not had any luck. If you have an idea how about dropping aline. Thanks !! Buddy
The USS Tangier was built on a C3 hull, identical to the Bogue Carrier. So you can download the Bogue plans from here http://www.hnsa.org/doc/plans/cve53-d79.pdf and just use the hull portion. I also sell a lasercut hull for the Bogue which he could use to build the Tangier.
Yes, the C3 hull was used by hundreds of ships. But you have to be careful, C3 is a general designation, there is some variation between different versions. The best reference I have found is here: http://shipbuildinghistory.com/hist...oships.htm From my research, the C3 Mod, C3-S1-A3, C3-S-A1, C3-S-A2 are either identical, or within the allowed building error of the Bogue hull.
