MAV-3 = CHECK VALVES
Discussion in 'Weapons & Pneumatics' started by Evil Joker, Apr 1, 2008.
  1. Evil Joker
    Evil Joker Member
    if i have a mav-3 in my radio box do i need a check valve. if so what kind
  2. GregMcFadden
    Not necessarily. The mav 3 valve will when not activated, vent the output side of the valve into the box. Unfortunately I don't have the check valve part number handy.
    If you are using a mav 3 to actuate mav2's using actuators, you will eventually over-pressure your box and either hold the mav-2's on or blow up your box. Generally the latter.
    If you use a single mav 3 to fire a single cannon, it will vent when not firing the cannon, however it is not good practice and unnecessary.
  3. Evil Joker
    Evil Joker Member
    um using a mav 3 to actuate two mav2 so if eneyone knows the check valve part # can you let me no. i dont need my box to blow up. ty steve
  4. Powder Monkey
    is that the MNV-1K (test Port)
  5. Kotori87
    If you put a check valve on an MAV-3, the overall result will be the same as if you had used a MAV-2. The check valve will prevent the gas inside the MPA-3's from venting. While that does prevent your watertight box from getting blown up, it also prevents the MPA-3's from releasing the MAV's that they are attached to.
    You could just use an SMAV-3. That's the sub-miniature version, and its vent port is NOT through the button. It's actually on the bottom, so you won't overpressurise your watertight box :) The SMAV-3 doesn't flow quite as much air as the MAV valves do, but since you're only using it to trigger poppets instead of firing a cannon you should be fine. SMAV-3's are also commonly used as the firing valve in Big Gun cannons.
  6. Evil Joker
    Evil Joker Member
    no i need to put the check valve on my box i need to no the part # of the check valve
  7. Gascan
    In that case, I just tried Clippard's website, www.clippard.com, and found the MCV-1, which appears to be what you want. Take a look at what they say about it.
  8. Kotori87
    Oh, so that's what. You use the check valve to depressurise the box, without letting any water in. Clever!
    I just had an interesting thought. If you put the check valve on the bottom of the box, then if the box leaked it would force the water out of the box before the overpressurised air. Just like a submarine ballast tank! Probably not practical, but interesting nonetheless.
  9. Evil Joker
    Evil Joker Member
    WOW. i think i will put it on the bottom now that you said that.ty good 1 will try it let you know
  10. Powder Monkey
    I’m on to that as well what was the final part #? Or are we still undecided [:D]
  11. Evil Joker
    Evil Joker Member
    MCV-1 but i havent got it yet
