Motors
Discussion in 'Propulsion' started by OverThinker, Jun 16, 2020.
  1. OverThinker
    OverThinker Member
    Florence Alabama
    so what is a good reliable.... and fairly inexpensive 6v motor to run? I need 3 for my Bismarck
  2. bsgkid117
    Johnson 550 cans. What rule set are you building this Bismarck for? Most people don't power all three shafts. Will seriously negatively affect the boat's ability to turn.
  3. rcaircraftnut
    Oklahoma
    Easiest setup would be similar to what I have in my Scharnhorst. Two 550 cans geared to a single shaft. Use drag disks on the outer shafts.
  4. rcaircraftnut
    Oklahoma
    Battlers connection has the gearboxes, motors, speed control, and shafts all for this ship. They call it a drive system.
  5. OverThinker
    OverThinker Member
    Florence Alabama
    What is a drag disk?
  6. wdodge0912
    wdodge0912 Well-Known Member
    Doesn't matter
    a solid disc that is the same diameter as you prop, that is on the outer shaft and doesn't spin
  7. BigGunJeff
    BigGunJeff Well-Known Member
    I think the idea with drag discs is that it allows you to maximize propulsion from the prop(s) that flow best over your rudder. Since the motors are typically vastly overpowered relative to scale you can have an inefficient hull drag-wise and overcome this will some extra power from the motors. Small price of using a bit more power, but the payback in terms of improved steering is well worth it.
    rcaircraftnut and OverThinker like this.
  8. Garrett
    Garrett Member
    santa cruz ,CA
    what do you guys recommend that I use for my cruiser with four props and a top speed of 40 knots.
    thanks
    -G
  9. Z Boat
    Z Boat Well-Known Member
    Roseville California
    You will only need 2 motors and Jeff has a link to a motor that works for smaller boats.
  10. Garrett
    Garrett Member
    santa cruz ,CA
    hmmmmmmm but my boat has four prop shafts don't I have to have four motors?
    -G
  11. BigGunJeff
    It would be a lot easier to power two screws. Probably the inboard ones.
    For optimal turning, you want to put your forward thrust out of the props closest to your rudder
  12. Garrett
    Garrett Member
    santa cruz ,CA
    ok and the front ones are just dummies right
  13. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    What format are you building for?
  14. Garrett
    Garrett Member
    santa cruz ,CA
    big gun
  15. BigGunJeff
    Yup
  16. Garrett
    Garrett Member
    santa cruz ,CA
    ok thanks
  17. buttsakauf
    Garland, TX
    400 size family motor on gearboxes or 550 direct drive. With big gun there are many options because you just need the rpm to make the relatively slower speed.
  18. Garrett
    Garrett Member
    santa cruz ,CA
  19. SteveT44
  20. BigGunJeff
    Garrett I run those G9332 motors (actually marked Johnson 30011 373002) in all of my ships. They work great direct drive, and tend to have loads more power than is useable for a 1:144 scale ship with a standard hull and no drag disks. I use a simple piece of polyurethane tube between the prop shaft and the motor to serve as a flex adapter. My Alabama is running the two inboard screws only and I have to limit my max speed in the radio to keep her legal. I have a Roma that has 4 powered screws and its the same issue... I have to limit throttle in the radio to not exceed her top speed.
