Need some SteamPunk measurements verified
Discussion in 'Steampunk Flotilla' started by SteveT44, Jul 18, 2017.
  1. SteveT44
    To any builders that started on an AC hull at Clark's build session a while back. Can you verify the vertical measurements in this drawing? If they vary from what you all built, please provide the as built measurements.
    Thanks
    Steve
  2. Beaver
    Image isn't there.
  3. SteveT44
    Hmm. It's viewable on my PC and Chromebook.
  4. Beaver
    Try downloading it and reposting.
  5. NickMyers
    If you reference an attachment directly like that its only viewable to whoever could view it in its original location. So if you uploaded it to a private album, you alone. If a conversation, you and whoever else was in it. If a closed subforum, then only someone with access to the subforum.
  6. Beaver
    Wait, there are secret subforums? Is there some dark underworld beneath the forums that we haven't been told about? o_O
  7. NickMyers
    Anywhere there are people there are dark unterwelten
  8. SteveT44
    Should be able to see the image now.
  9. SteveT44
    Ok Punk dudes. Can't anybody who's got one of the AC's started verify the measurements on this image?
  10. thegeek
    Looks like SAE, and a stack of blocks?
  11. Beaver
    -BUMP-
    @Tugboat @irnuke @McSpuds can any of you tell us if the measurements on Steve's drawing are the same as on your AC, or if not, what those measurements are?
    Thanks!
  12. Kotori87
    Hope this helps.
    Xanthar likes this.
  13. Xanthar
    Xanthar Well-Known Member
    Upstate NY
    I love that that cat is holding the ship steady for you : P
  14. irnuke
    Couldn't figure out a way to imbed image, but the spreadsheet attached shows my ships measurements. Note that the bottom is already bondo'd together, so it totals 1" combined.
  15. Beaver
  16. SteveT44
    The IRNuke measurements match mine. Kotori's pic show the bottom window 3/16" taller than the drawing.
  17. SteveT44
    Is this one of the hulls built at Clark's build session?
  18. irnuke
    I think we could live with a 3/16" taller hull. After all, it's more penetrable area :p
