Nikki's LST
Discussion in 'Warship Builds' started by NASAAN101, Nov 2, 2011.
  1. NASAAN101
    Guys,
    Other Then My Andera Doria, I have an LST! But her two motors are linked together, But not counter rationing, and I'm not sure how to do that? Dose anyone have anyway any ideas on how to do that, I was looking at putting a gear box in, but she's two little!!! I know one of my friend to me to do the + to -and - To +! is that true???? here are the photos of her: http://s575.photobucket.com/albums/ss192/NASAAN101/LST/ she was my first, and will later on she be a target for the Doria!!
  2. mike5334
    Nikki, post a picture of the motors and wires on them please.
  3. hairy_apple
    hairy_apple Member
    Cute little LST. I really like the LSTs, it's on my list of ships I'd like to build someday.
  4. absolutek
    Nikki, if I may make a suggestion, why not go to YouTube, and watch a few videos on how a dc motor works? While you're at it, go to wikipedia and read about dc motors. Try helping yourself for a change, if people see you making an effort, they will be more likely to help.
    Chase
  5. NASAAN101
    chase,
    the motors we use are the brushed motors, right? my mom asked me, and i wasn't so sure!!!
    hairy_apple,
    I love her! She was my first ship!!
  6. absolutek
    they are brushed DC motors, yes.
  7. NASAAN101
    mikey,
    I have all the photos of the motors and the contectors she had on her, and i wasn't sure any they were go to put on those photos!
  8. NASAAN101
    mikey,
    the first two photos are of the motors: http://s575.photobucket.com/albums/ss192/NASAAN101/LST/
  9. mike5334
    The pictures really aren't clear how the motors are wired, yet I think we can work with this.
    On one of the motors (probably the left motor in the pictures), swap the wires between the motor's terminals. For instance, the black wire is on the left terminal, and a red? wire is on the right terminal, then move the black wire to the right terminal, and red? wire to the left terminal.
    That will reverse the power through the motor and make it run in the opposite direction. That will give the LST counter rotating props.
  10. NASAAN101
    I was bored off my butt, so in 15-minutes I got the motors out, and one side of the boat un-scheeted!!! bit mom didn't went me to go any more be on that!! but sunday, i thing were going to we wire the motor and tested them on one of the 6volt batteries!!
  11. NASAAN101
    hey guys,
    what is the best size wire to use on the 6volt motors???
  12. Tugboat
    16 gauge is plenty for a convoy ship. If you want to go overkill, go to 14, but that's way more than you'll need.
  13. NASAAN101
    thanks tuggy,
    i wasn't sure!! ok, the red and black wire for the ham radios are what, 12 or 16
    gauge
    ?? i'M not sure!
  14. Tugboat
    oh, that varies a lot, depending on how much power the radio needs. You can buy some pretty generic 16 gauge at Radio Shack that will do the job nicely.
  15. NASAAN101
    YA, I was thing that to!!
  16. NASAAN101
    Guys
    I'm not sure if this will work but I went to ask now now, when i put the wires on the motors! Left motor its Positive - To - Negative and then with the Right motor it's Negative - To - Positive, right??? I just went to make sure I'm going this right! With this being my first time wiring the motors on my own!!! sorry for being a nag with this!!!
  17. DarrenScott
    Nikki, it all depends on your props, and which way you need them to turn. You should have one LH prop and one RH.
    You are correct, one of your motors will need to be wired opposite to the other.
    Have you got your props fitted to the shafts yet?
  18. NASAAN101
    Guys,
    I have everything on her props and rudders But not the inters!!! I got a lot of new stuff for my lst! and I was going to build two watertight boxed (One would be for the Receiver and the other would be for the speed control and Fan)! But with my LST only having two channel Receiver, I'm not sure how a speed control would work with her! Plus a battery holder?
  19. DarrenScott
    The speed control will work on one channel, and the rudder servo will work on the other.
    What speed control do you have?
    I'm not a big fan of watertight boxes, I've seen too many fail.
  20. mike5334
    A fan in a watertight box?
